Question about Acer Aspire 3680 Laptop
3680 2682 Laptop fell off bed to floor w/ USB drive plug in back
Laptop fell off bed to floor with USB drive plugged in back. That seems bent, so does it need repair? altho it still works. Is that good place to plug in drive or is left side better?
  • 238 Answers
Hi, if the port is working fine, its ok.. but do not use this port, since its damaged, it could short the pins inside while pluging the cable, left side is better
Posted on Jan 03, 2008
Bent flash drive
Unfortunately this drive is impossible to repair if bent (like from dropping while attached to laptop) and it cannot be recognized when plugged into your laptop. The silicon memory chip is sandwiched between the PCB material, if you take the case off of the outside you can observe that it is just a black square piece of silicon with no traces on the board only the metal pads to connect it intothe USB port. the "faceted" portion of the drive is only for grip and has no use other than a way to remove it from your laptop. The memory is very close into the connector, so when I dropped my laptop it bent it directly down the middle of the memory chip portion itself, undoubtedly severing thousands of microscopic connections in the chip. I believe this is a very poor design and will be buying the older "switch" style usb drives in the future.
Jan 31, 2014 | SanDisk Cruzer Facet 8GB USB 2.0 Flash...
1mb com
how do i get free wild coins and how to unlock code
Jun 19, 2013 | Computers & Internet
Toshiba SAT A505-S6005 Power cord was plugged when laptop fell to the floor and hit where the cord attaches to the receptical (on computer) which jammed (pushed) the thin connector prong further into
When this happens it means that the whole recepticle has been broken off of the motherboard and the whole laptop will have to be disassembled. This is not an easy job for someone who hasn't done one before. After it's disassembled it has to be determined if the recepticle can be resoldered or not. Sometimes the damage is not repairable. Good luck!
Nov 22, 2012 | Toshiba Computers & Internet
My external hard drive fell off my bed onto the floor. Now it is no longer recognized by my computer. How can I retrieve the data that is currently on the hard drive.
Well this could be a tough one.
It seems likely that how much experience you have working with hardware as well as how willing you are to work with computer hardware my be a big factor.
Anyway. At this point does the external drive show ANY signs of life? Does it's led come on?
Does the drive seem to come to life? In other words. Can you heard the drive spin up (or spin in general for that matter)?
Also does the drive make any loud clicking sounds? Does the drive make any sounds that it was not making before it fell off the bed and on to the floor? Or is it failing to make any sounds that it always made before it fell off the bed?
Here are a few suggestions:
First consider carefully how valuable the data you wish to retrieve really is to you as opposed to how valuable the drive itself may be to you. For example, is this drive still under warranty?
If you open up the box it will void the warranty. If it is still under warranty they will probably replace it. So this is a serious consideration.
If the drive is no longer under warranty then it is not an issue.
If your drive shows NO signs of life then it is not getting power for some reason. This could be anything from a broken or disconnected wire inside the box to a broken interface printed circuit board.
If the led lights up but the hard drive does not spin up then this could also be anything from a broken or disconnected cable inside the box to a broken interface printed circuit board. It could also be that the drive has suffered catastrophic damage. If it is the later your data is history.
If the drive is making any loud sounds it never made before it is also highly likely that your data is history.
You can open the box your self and check for problems like disconnected or broken cables. Which should be easy to fix.
In any event good luck...
Jun 12, 2011 | Western Digital WD My Book Essential 1TB,...
I have a my book home edition 500 gb usb hard drive. it is not being recognized by the computer when it is plugged in. however, the blue light lights up solid but does not show that it is working. It seems...
As you are saying that its usb port on back is bent try to replace it or try to change its (hard drive) whole cover and get a new one from market. External hard drive case.
for any other help or to thank me Mail me on email
Aug 06, 2010 | Western Digital My Book Home Edition 500...
My iomega portable hard drive fell off the table onto the floor and now it does not work it makes a funny high pitched beeping noise and does not sound like the drive disks are moving. What should i do?and...
I don't know this hard drive to well but I know that when a hard drive is dropped/fallen onto the floor, it probably won't work seeing as they are fragile. You'll have to phone the company that created/imported this drive because they'll have the spare parts to fix it.
Dec 07, 2009 | Computers & Internet
Seagate 1.5TB dropped from office table... TWICE.
the drive is damadged internally, you have to phone or email a data recovery centre to get your data back, that can cost $1500+ because of the size of the disk.
Oct 03, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to
Oct 18, 2008 | Buffalo Technology 320GB MINISTATION TURBO...
Acer Aspire 3680 Laptop Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
