Question about D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps Networking Switch
Tcp ports i want to connect to my d-link DGS-1005D so i can configure my tcp ports. Im running vista, im using the d-link to connect two computers to the internet, PLEASE HELP
I want to connect my lexmark printer to my d link and have two computer use the same printer but i don't know how to make it work, can some one help me.
Posted on May 15, 2008
    Problem Solver:
  • 10 Answers
It depends on the type of internet service you have if it is cable internet most cable modems can act as a gateway for conecting multiple computers but the cable company needs to activate that feature on the modem.
Posted on Jan 04, 2008
How to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Well my friend found me a d-link router and all it came with was a power cord and the router itself and when i searched up the name for it i got D-Link DGS-1005D 5-Port Gigabit Switch. i am not sure how to...
you can find all the data you need in the following PDF manual
ftp://ftp.dlink.de/dgs/dgs-1005d/documentation/DGS-1005D_man_en_v2-01.pdf
hope this helps.
Dec 28, 2010 | Computers & Internet
Hello, Got a D-Link 1005D 5x100 Im having 2 computeres atm, but i cna only get one to work. When i plug the internet cables from the computers to the D-link router, only one can work, please...
Your D-Link is a "switch", not a "router".
So, every computer that you connect will require a _UNIQUE_ IP-address.
However, your account with your Internet Service Provider is only granting you *ONE* IP-address.
Upgrade your account to pay a few dollars more per month, to get additional IP-address(es).
Buy a D-Link Router, for under $50, and connect both computers to the 'LAN' ports,
and connect the 'WAN' port to your cable-modem (or DSL-modem).
Dec 08, 2010 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Hi, it seems as it get stuck, stop all trafic. After disconnection and reconnect it works again, Any ideas?? Lights flckers as if trafic is going on /Steen
Take a look at the location you have it placed in. These off the shelf solutions are nice quick fixes but they over heat easily. This causes the firmware to crash. So you reset 'em and all is well again. Until it overheats again. Check out Ubiquiti's bullet router. I've got one running 100 computers and I havn't had an issue with it yet.
Nov 11, 2009 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Re:D-Link dgs-1005d mounting plates
For this as per my knowledge there are no extra mounting plates comming commercially. But itself having some mounting tools such as wall plug, screw etc. in it's package....and for permanent installation if you need it very much you can order such thing in turning workshop...but try to use it in friendly environment....because those are heat and hazard sensitive for heavy duty.....All the best.
Oct 20, 2009 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
HI! I got my Pc set up through a Dlink 1005d to a router. Im able to access internet fine.. Now my problem is that I also want to connect a media player to the DLink aswell.. What happens is when I try...
It probably isn't an overload the flashing lights are probably the new device doing a broadcast trying to find something that will tell it how to configure its network port. This process is called DHCP (Dynamic Host Configuration Protocol)
Normally your router would be automatically configured to be a DHCP server. If you have not needed to manually configure TCP/IP on your desktop computer then You have a DHCP server turned on somewhere.
Your next step should be to find out where your DHCP server is and if your new device has contacted it. Find the manual for your router and have a read about how to configure it expecialy the bits about DHCP.
Then open a command prompt. Sometimes called a dos prompt by typing cmd in the start run box and type ipconfig /all The Default gateway should tell you the IP number of your router. type that IP number into a web browser like this. http://192.168.0.1 (or what ever it is) you should see a configuration logon page for your router. The username and password will be in your users manual or just google it. From here go into the DHCP server screens and you should be able to see what IP numbers have been assigned on your network. Hopefully one of them will be your new device. Also you need to make sure that you only ever have one DHCP server on your network. PC's can also perform this function. If you have more than one running it will very dificlut to diagnose. If you see ip conflict errors this is probably the cause.
Netowrking is complex and there is lots you need to know all at once. Luckily home networks are relatively simple once you know what all the pieces are. This should give you a taste of what you need to learn about.
Good luck :)
Aug 15, 2009 | Computers & Internet
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Connecting xbox live to my d link 1005d
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Adam
Oct 26, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
2 pc connected but wont allow both on internet at once
Set up both pc's with dhcp. To do this, right click (My Network Places) in the start menu and choose properties. Right click your network connection and again choose properties. Click Internet Protocol (TCP/IP) and then select properties. Choose (Obtain an IP Address Automatically). Then (OK) and again (OK). Do this on both pc's.
Nov 13, 2007 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps Questions
D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps Networking Switch Logo
362 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
