Question about Samsung YP-K5 MP3 Player
Samsung yp-s5 drivers download
I try to download the zip file from samsungs website so my computer could find the Drivers for WINDOWS VISTA but when i download the file and unzip it wit winrar theres a folder that says S5J and i click on it and says theres nothing in the folder .
  • 6 more comments
  • drenched Jun 13, 2008
    I have vista & my samsung S5 won't work with it. It doesn't have the drivers. The Samsung website only has downloads for manual, software & firmware for this model...no drivers. Excellent. Any help?
  • Anonymous Oct 15, 2008
    gfd
  • Anonymous Dec 13, 2008
    kurwa
  • Anonymous Jan 09, 2009
    i have the same problem as you :-(
  • Anonymous Jan 14, 2009
    kurwa
  • maria cook
    maria cook Jan 17, 2009
    I have A samsung S5 and my laptop is running on XP. It used to work just fine on windows media player and the media siut disk I got When I perchased the player. Now my computer cant even read it and I can't even find drivers for it. Please some one can you help?
  • ths-75 Feb 09, 2009
    jlkjlkjlkj
  • roxichik Mar 16, 2009
    I have just brought the Samsung S5 MP3 player....I've run the installation CD but my PC does not recognise the Device. It says no drivers. I tried to download the drivers from the Samsung website but it keeps on coming up with some error. All I want is the drivers for the MP3 player......HELP!!!
Hey
Posted on Dec 14, 2008
I've had this problem as well. Return it if you can and get your money back. The charge doesn't last half as long as it's supposed to as well. I did eventually get the drivers to work from downloading an older program from samsung's site a while ago. I don't know which one, I just downloaded everything and one worked. It's a hassle. Hope that helps a bit.
Posted on Aug 18, 2009
    New Friend:
Please solve my driver problem [email protected]
Posted on May 20, 2011
6ya staff
SOURCE:
Why won't Xbox update?
To resolve this problem, try the following solutions.
Solution 1: Check your Xbox Live connection
If you're having problems connecting or staying connected to Xbox Live, see I get an error message when I test my Xbox Live connection.
If you still experience the problem, try the next solution.
Solution 2: Clear the system cache
Removing the temporary files on your console might solve the problem. Follow the instructions at How to clear your Xbox 360 system cache. Then, try downloading the update again.
Solution 3: Copy the update to a USB flash drive, CD or DVD
Copy the console update from your computer to a USB flash drive, CD or DVD, and then install the update on your console. Here's how:
Copy to a USB flash drive
Note The USB flash drive must use the FAT32 file system.
  1. Plug your USB flash drive into a USB port on your computer.
  2. Download the update file.
  3. Click Save to save the console update .zip file to your computer.
  4. Unzip the file:
  • If you are using Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  • If you are using an earlier version of Windows, you need to use a special software program to unzip the file (for example, WinZip).
  1. Copy the contents of the .zip file to the root directory of your USB flash drive.
  2. Unplug the USB flash drive from your computer.
  3. Plug the USB flash drive into a USB port on your Xbox 360 console.
  4. Restart the console.
  5. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Burn to CD or DVD
You can also download the update to your computer, burn the update to a CD or DVD, and then install the update on your console. Here's how:
  1. On your computer, download the update file.
  2. Click Save to save the console update .zip file to your computer.
  3. Unzip the file:
  1. Insert a blank, writeable CD or DVD into your computer.
  2. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  3. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
Dec 15, 2013 | Microsoft Xbox 360 Console
We need a driver for the Lexmark z65 for our Windows Vista and our Windows 7 systems.
Welcome to Fixya
Lexmark already discontinued supporting this product. The last driver made for this product is for Windows XP only. Yo may try this work around procedure if you are using Windows Vista or Windows 7. Download CJXP65NLE.exe at Drivers and Downloads (under Windows XP) from the Lexmark website. This file downloads as a zip file. Download it and unzip but do not allow the automatic Setup file run(Note where the file saved to). Now go into the Control panel and under the Printer Icon select Add a printer. Add local printer under existing port using virtual USB printer port. Now select "Have Disk" and select the folder that the Lexmark file unzipped to. Continue the installation. You might get some warnings that the driver is not Digitally signed, ignore them to finish the installation. Once the installation is complete your printer should work. The only downside I've seen so far is that the printer's full features from the original Z65 software are not available.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 26, 2011 | Lexmark JetPrinter Z65p Photo Color InkJet
HOW CAN I GET IBM THINKPAD T43 ETHERNET DRIVER.
ThinkPad can havedifferent types of network, video and audio drivers. You need to download allthe drivers and install each driver until you find the right driver unless youknow exactly which one is installed in your ThinkPad. Write down the devicedriver and it's file name after downloading, so you have a record of whichdriver you are installing and which directory the unzipped files are located onyour hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Follow the bellow link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true After download the various drivers and click on andrun the various driver files, they will then unzip and expand into a sub folderon C:\drivers Then install the various drivers from this folder (run the set-upfile). http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do Now you can download easily one after one. After downloadall the driver, unzip the fie with winrar or zip. Download the winrar free, Copy the link and paste on address bar. http://www.filehippo.com/search?q=winrar Install it.
Hope this helps
Feb 25, 2011 | IBM Computers & Internet
How to update your xbox360
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet. To learn how, please see Connecting to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
If you cannot connect your Xbox 360 console to the Internet, you can copy the console update from your computer to a USB flash drive and then install it on the console.
Note: The USB flash drive must use the FAT32 file system.
  3. Click Save to save the console update .zip file on your computer.
  4. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
  5. Copy the contents of the .zip file to the root directory of your flash drive.
  6. Unplug the USB flash drive from your computer.
  7. Plug the flash drive into a USB port on your Xbox 360 console.
  8. Restart the console.
  9. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
You can update your Xbox 360 console software by downloading the update to your computer from Xbox.com, burning the update to a CD or DVD, and then installing the update on your console. Here's how:
  2. Click Save to save the console update .zip file on your computer.
  3. Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using Microsoft Windows XP, Windows Vista or Windows 7, double-click the .zip file to unzip it.
    • If you are using an earlier version of Microsoft Windows, you need to use a special software program to unzip the file (for example, WinZip).
  4. Insert a blank, writeable CD or DVD into your computer.
  5. Copy the contents of the .zip file to the root directory on your CD or DVD, and choose to write (burn) the files to the disc.
  6. Once the files have been burned to disc, remove that disc from your computer and insert it into the disc drive on your Xbox 360 console.
  7. Restart the console.
  8. When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Feb 04, 2011 | Microsoft Xbox 360 Console
I have downloaded Drivers for Olympus VN-4100PC but cant install them as they are a zipped file
On any computer running Windows XP or Vista or 7,
right-mouse click on the ZIP file, and choose "Extract All" to start the "unzipping-wizard".
Once unzipped, look for a "setup.exe" file in the newly-created folder. Double-click to run that program.
Jul 07, 2010 | Computers & Internet
HOW TO UNZIP THE UMR305.ZIP
usually windows xp , vista has incorporated software to unzip zip files
you can also use winrar do extract contents from zip files
Jul 24, 2009 | Computers & Internet
Olympus W-10 cannot interface w/ computer (mac/win)
http://www.olympusamerica.com/files/VoiceAlbum.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
The software is only compatible to a computer running Windows XP or earlier. It is not compatible to a Vista OS.
Jul 23, 2009 | Olympus LS-10 Digital Voice Recorder
Samsung YP-K5 MP3 Player Logo
8,428 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
