Classic Clutch malfunction with the FAV6800AW and FAV9800AW. Take a look at this post and see if it will get you started.The post is for DIY folks. If you or someone you knowcan’t take this on call in an appliance service repair company.If you want to DIY the fix I will help you every step of the way.
Anyone with basic mechanical skill sets can do this and you can be back in service today if the one–way roller clutches can be cleaned up and re-lubed.Take a peak at the post and see if you can save yourself $. I believe to have it repaired will cost you in the $300 range.
You could have a failed Tube Displacement Sensor but a quick check will prove that out.I’ll attach the process but it’s in the service manual and it’s free.
Tub Displacement Sensor Diagnostics check. It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshootingguide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you get these results your TDS sensor should be just fine.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
The door does not lock and unlock thereby making it impossible for the washer to start when the...
(More)
The door does not lock and unlock thereby making it impossible for the washer to start when the button is pushed
The fabric softener and bleach do not dispense during a cycle. They remain full after the load is...
(More)
The fabric softener and bleach do not dispense during a cycle. They remain full after the load is complete.
