Question about Sanyo DS31590 31" TV
PS2 hook-up When I hook up the PS2 to the tv (white, red, and yellow cord) and switch the tv to video mode, the screen is blue and all i hear is the game playing.  I tried a variation of different colors instead of using all 3 and nothing works.  Both red and white are left and right audio and yellow is video.  It wouldn't make sense to NOT have all three, either way, video doesn't work, only audio does.  Is there something I can do to fix this, or does it have to do with the yellow input on my tv that is permanently not fixable?
  • Anonymous Feb 24, 2009
    my ps2 makes sond but it only shows a very faint screen an d plays when you cant see
  • 2,336 Answers
I would suggest to feed video from another source such as DVD or VCR to the same input, if the video is visible from other sources on your TV; that means the video cable from your PS2 is defective. If you did not see any video from the DVD or VCR nor the PS2, it means that there maybe a loose connection inside the TV on the video input.
Hope this helps.
Posted on Jan 16, 2008
How do you connect a ps2 to the led24916dvdfhd
Well the LCD or TV must have rca..jacks yellow video..red and white is audio..if not u can get a component jack wires for PS2..red.blue..green...video....red and white audio..the TV must have those connections ..for PS2..or get old school cable connected hook ups for PS2..hooks in cable or antenna connecter on TV..UHF connected for ps2
Jul 21, 2014 | Video Game Consoles & Games
How to hook up the wii cords
First, you are posting a question about the Wii under the PS2 heading. Problem number one! Number 2! If your TV is new enough, it might not have the connections for A/V jacks like the yellow red and white. Here is how they connect. Yellow, video, Red, right sound, white, left sound(mono)
Jun 11, 2014 | Sony PlayStation 2 (PS2) Console
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
I need a printable version of how to hook everything up. Please. We have a PlayStaion2
  1. Place your ps2 in an area that will allow for plenty of airflow, and is relatively close to the television that you intend on hooking it up to.
  2. Step 2 Check your TV or monitor for available video inputs. The most common are composite cords, which come with a new PS2. This cord has one plug on one side, with the other side having three ends colored yellow, white and red.
  3. Step 3 Plug the single end of the video cord into the back of the PS2. Plug the other side of the cord into the corresponding colors in your video input on your television.
  4. Step 4 Plug the AC adapter (power cord), into the back of the PS2. The other side of the cord should then be plugged into the wall. A red right will appear on the front of the PS2, signaling that it is on standby mode, and receiving the required power.
Jan 05, 2010 | Sony PlayStation Portable (PSP) Console
I have 2 ps2 how do i link them to to tvs
SONY Instutions that came with it.....
SIMPLE: CONNECT THE FOLLOWING TO THE TV FROM THE PS2 VIDEO CORD.
YELLOW TO YELLOW
RED TO RED
WHITE TO WHITE.
Coax is much simplier.. Screw the Coax cord to the back of the PS2 to the TV.
Jun 29, 2009 | Sony PlayStation 2 (PS2) Console
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
TV does not recognize PS2 input
On the TV you should have a video, input or mode button. If you press that button while the PS2 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Mar 21, 2008 | Emerson EWF2004 20" TV
DVD and PS2 in Black and White
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Sanyo DS31590 31" TV Logo
206 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
