Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher is running but no water is coming out
Dishwasher is working but no water at all is coming out of the top or bottom sprayers
  • Anonymous Jan 13, 2008
    Kenmore Dishwasher running, but not water at all.
  • skerpla Jan 14, 2008
    I've had to call in service for this one as dishes (esp top shelf) were not getting washed or even wet...1st tech ordered new sprayer arms, water tower (the pipe at the back that brings water to the top arm) and a new pump, all without taking anything apart...when the 2nd tech came to install them all he found the masticator screen was plugged and no water was getting back to the pump for recirculating. Since then I have taken the machine innards out and cleaned it myself, but it is definately not user friendly to do this. Jar labels are the worst culprit, but they aren't easy to get off before you put them in the DW. My old portable would chew up nearly anything you threw into it and was very easy to clean. I thought I was doing the right thing to get a new machine.I'd like to know if there is any easy way to add a prefilter that would be easier to clean...before the gunk gets past the sprayer arm and past a bunch of parts requiring wrenches and screwdrivers. Not sure if I have the same model listed but problem seems to be the same
    Thanks
    Scholar:
  • 64 Answers
Make sure that you have enough water pressure from your tap. If pressure is okay check the door to make sure it is closing and latching properly. If the water is making it through the hose(s) but not actually spraying internally you may have a broken water pump, or a clog ie. calcium build in the lines. Try just cold water too and see if that makes any difference.
Posted on Jan 03, 2008
Lg dishwasher top rack sprayer gets no water and not not spraying, middle rack sprayer gets water but not spinning. Bottom rack works fine
Check and make sure the tubes that go into the back of the dishwasher are aligned. Sometimes they get out of place.
Oct 21, 2017 | LG Dishwashers
The top section wont wash clean
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
I have a GE Profile Dishwasher Model # GSD4940Z00SS. It does not wash very well. Water stays at teh bottom after each wash cycle. We have blow air through tubes and looked for obstruction but can not...
I had a similar problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Dishwashers
DISHES ARE NOT COMING CLEAN BYPASSED THE DOOR LATCH TO WATCH CYCLES,LOOKS LIKE THERE IS NOT ENOUGH WATER PRESSURE TO ACTIVATE THE WATER TOWER AND ROTATING ARM?WATER PUMPS OUT BUT NOT ENOUGH TO MAKE THINGS...
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Dishwasher not cleaning dishes
Aug 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Top water injector not working
Aug 24, 2009 | Frigidaire 24 in. FDB126RB Built-in...
Maytag jet clean model#dwc7400aaw
Check to see in you have enough water in tank. The dishwasher fills then recirculates this water under pressure. If you have water in tank, listen to see if motor is running or not. If it is, you may have clogged jet holes in the wash arms.
Jul 31, 2007 | Maytag MDB9600A Jetclean II Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
63 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
