Question about Honeywell Programmable Thermostat Heater
HEATER DOES NOT TURN ON BUT AC WORKS.
HEATER PROBLEM
  • 236 Answers
- If no voltage output at the thermostat for the supply of heater/reversing valve, then replacement of thermostat is needed (but check the thermostat setting).
- If the voltage output at the thermostat for the supply of heater/reversing valve is present, then then check for heater/reversing valve fuse or overheat protection, and check for defective heater/reversing valve
Posted on Jan 03, 2008
Nissan Ac problems
vent flap shutting off?
Jan 14, 2018 | Cars & Trucks
The air mixing doors is stuck
It could be run by a vacuum pipe, check and listen to see if you hear air escaping, if not then it could be electrical
Jan 04, 2014 | Cars & Trucks
Speedometer, cruise light , ac/heater control doesn't work
Sounds like someone needs to do some more troubleshooting first. Changing the cluster is not a simple matter since your mileage will be different. And the cluster is on a different circuit that the ac so one should not affect the other.
Jun 27, 2013 | 2002 Chevrolet Impala
Heater fuse blows when ac is turned on
poor Wire connection on the breaker? Is the wire screwed down tight? SHUT THE MAIN OFF FOR SAFETY, then pull the breaker off the buss bar and inspect the bussbar and bottom of breaker for any burn.
It’s helpful to also use and ampmeter to check equipment amp draw vs. the amp rating on the equipment tag.
Jan 27, 2018 | Goodman GMS90703BXA Heater
1992 honda accord radio and ac stopped working
Make sure your fan is working properly. When you turn on the heater you are forcing the fan to cool the radiator. It may not be turning on automatically when it is supposed to. Let us know if this helps..
Oct 09, 2012 | 1992 Honda Accord Coupe
1997 Nissan 4 cylinder truck AC works excellent throwing snowballs cold air, then it will blow hot air. Relay switch and clutch has been replaced....Did not fix problem!
sounds like compressor isn't working properly or heater vacuum is opening vent to heater core.try turning on ac and if it cuts on and off repeatedly every few seconds the freon level is not correct or high pressure switch may not be working make sure radiator fan comes on when ac is on.if all this is working properly check vacuum hoses to heater may be opening vent doors to heater.hope this helps
Aug 11, 2010 | 2005 Nissan Altima
THE AC WONT BLOW OR THE HEATER
CHECK BLOWER MOTOR FUSE AND RELAY.IF BOTH GOOD.REMOVE BLOWER MOTOR HOTWIRE IT.IF DONT WORK REPLACE BLOWER MOTOR.IF BLOWER MOTOR WORKS.HEATER AND AC CONTROL SWITCH IS BAD.
Apr 30, 2010 | 2005 Chevrolet TrailBlazer
Heat/AC doesnt work
is the switch on dash in one piece as on these cars the bottom of the switch breaks ,you push switch to turn on a/c and turn it for the fan left is re circulate right is fan with fresh air in as well
Jan 08, 2009 | 1999 Ford Escort
Heater control wont heat. AC and fan works fine
mechanical or vacuum operated valve that releases hot coolant into the heater core may be stuck closed. or the heater core may be clogged. hope this helps.
Aug 10, 2008 | 1997 Pontiac Bonneville
Heating & Cooling Logo
1,661 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
