Question about Sony Handycam DCR-TRV320 Digital Camcorder
Dcr-trv320 problem My camcorder worked well until the door was lifted to many times to eject and the relay ribbon wore into to the door where it hinges, now I have no functions on the door. Can that be fixed?
  • 30 Answers
Hi, The the door cannot be fixed. You need to replace it. It's called a switch block control ***'y.
Ask if you need a part number.
mr cicmo
Posted on Nov 18, 2008
I bought a new Memory stick for my Sony DCR-TRV320 Camcorder and when i switch my device to memory mode, it tells me "Memory Stick Error."
Check the following:
Memory Stick is inserted in correct position and orientation in camcorder. Try re-inserting several times.
Write-protect tab is switched to allow writing to memory stick (on back of memory stick)
Memory Stick is formatted in FAT file system (this should already be done except if memory stick has been formatted in a computer in a different format)
Memory Stick is not over the maximum capacity memory stick of the camcorder.
Memory Stick is not full.
Memory Stick is clean and dry.
The dcr-trv320 is a 2000 yr. model and came with a 4mb capacity stick and can probably only use up to a 128mb capacity stick or possibly 256mb. Most memory sticks you can buy today are 1GB, 4GB, 8GB etc. memory stick pro duo. and are probably incompatible. E-Bay has some of the old memory sticks like the 128mb for sale.
There is a slight possibility that static electricity discharge zapped the stick. Try another memory stick or try the stick in another device.
May 02, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
I have a C:31:23 code showing up on my Sony DCR-TRV320 camcorder. Can't do any recording or anything. That is flashing along with an eject symbol. Tried another tape and same thing happens. What is up...
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Feb 12, 2011 | Sony Handycam DCR-TRV320 Digital Camcorder
DCR-TRV320 buttons aren't working!
Price of installing the zoom control cabinet assembly on the DCR-TRV 320?
Aug 31, 2009 | Sony Handycam DCR-TRV525 Digital Camcorder
Manual eject option for trv320? No tape in it. Won't open so I can put one in.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 06, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony dcr-trv320 won't record audio
Go in menu, go to sound and make sure it is turned up.
Jun 28, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Camera always returns to telephoto position
W-T switch is defective and requires replacement,
above part can be demanded under following part number for DCR-TRV320 camcorder...
1-418-799-11 SWITCH BLOCK, CONTROL (FK-10000)
If you have different model camcorder, let me know to provide you appropriate part number.
Dec 18, 2008 | Sony Handycam DCR-TRV320 Digital Camcorder
Transfer videos from handycam to PC
i will give you a step by step on your camcorder.
  • connect your camcorder using your USB cable to your computer and be sure it is ON
  • Install the cd driver camed with your camcorder. if you didnt prompt on looking for a driver then go to the add hardware on the control panel and follow the procedure there.
  • after the installation you should see the icon on the my computer labeled scanners and cameras and indicating the model of your camcorder.
  • Install Ulead Power Producer or any editing movie that you have like Windows movie maker, nero movier maker etc.. i prefer to use Ulead because its so easy to use
  • after uploading and editing your videos using ULEAD save it on any various types of videos that you like. you should see it after you want to save it.
  • burn your videos on NERO software
Hope you understand my procedures. Good Luck!
CHARCOIS
Nov 10, 2008 | Sony Handycam DCR-TRV320 Digital Camcorder
Firewire Port not working
HAVE YOU HAD THE CAMCORDER ON THE MAINS ADAPTOR WHEN IT WAS CONNECTED TO THE FIREWIRE AS IT HAS TO BE TO POWER THE FIREWIRE PORT!
Nov 08, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony DCR-TRV320
Try this (seems to be a standard thing from Sony):
  5. If an error message appears, service may be required. If the error ,message starts with an "E" it needs to be sent in.
Go to any large photo shop and get an estimate.
Aug 23, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony Handycam DCR-TRV320 Digital Camcorder Logo
96 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
