Runs autosetup repeatedly. Has been going on for some time. Usually only lasts a day. Now it won't stop; keeps going into video 1; won't keep the picture.KV-27FV300 WEGA.
I took out the cable TV digital box and the TV hasn't been going into auto setup for the last 4 hours.I took out the cable TV digital box and the TV hasn't been going into auto setup for the last 4 hours.
You can't post conmments that contain an email address.
Next time you try to start it, turn the key to RUN (not start)for 2-secs. Then turn to OFF. Repeat 3 times. Then try starting. If it fires right up, that's a sign of a leaking check valve in the fuel pump. Turning the key to RUN 3 times triggers the fuel pump to go into "prime" mode to rebuild fuel rail pressure. When fuel pressure is back up to spec, it fires right up.
you need to have a spacer put it ther to take up the slack in it ther was won in ther probably at won time or another replace it go to the dealer to make sure you HAve the Right One For Sure then go some Were Else to put it in and ask them Please can you Help Me Please Rember Be Nice And Be Thank full afterwards Ok
Press and hold C until day of the week is announced. It will say Monday. If you don't want monday use annc/skip to go to the next day. When you get to the day you want hit set. This will save that day of the week for you. Then it will annouce hour, select the hour by doing the same thing and after you have the hour press the set button. Do this for the minutes too. Lastly is the year, if you've went to 2027 and it won't loop back to 2007 say, you can usually unplug it and it will reset the year back to the factory setting.
