Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
High pitch shrill when input device not DVI
When ever the TV is not on DVI, there is a high pitch shrill sound regardless of sound volume. Cannot watch DVDs since the input device must be changed to CMP1.
  • Anonymous Jan 04, 2008
    High pitch sound when TV is on for about 5 min. Is it the signal board with surface mounted ic chips thats causing the issue?
  • BuckeyeDon Jan 13, 2008
    What is the flyback? Something on a the DVI connector board?
Inside the tv
Posted on Jan 13, 2008
    President:
  • 4,402 Answers
Use of silicon or superglue on a coil next to the flyback that solved the problem in a similar model RPTV. Easy fixes first
Posted on Jan 08, 2008
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Constant high pitched shrill when turned on
Sounds like the evaporator fan motor bearings are shot and the motor needs to be replaced. This motor is found near the cooling coil in the freezer section.
May 30, 2015 | Whirlpool Refrigerators
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
Sound Issue
This might be of the core vibration of the backlight inverter transformers.
Dec 09, 2012 | Televison & Video
Darker picture and high pitched sound from back of tv. Also flickers.
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Jul 31, 2012 | Televison & Video
How can I connect my Desktop computer to my Hitachi 57F500 TV? I have an emachines desktop, running MS Win 7 connected from Monitor VGA port to DVI port on TV via Dynex DVI-VGA cable, but not getting any...
Hello
VGA and DVI are not compactable. Your TV has no provision to connect it to computer.
DVI-HDTV Input (Input 1)
Use this DVI-HDTV Input for your external devices with DVI-HDTV output such as a Set-Top-Box, high-band DTV decoders, DVD
players and D-VHS with Digital Content Protection
1. Only DTV format such as 1080i, 720p, 480i and 480p are available for DVI-HDTV input.
2. The DVI-HDTV input is NOT compatible when used with a DVD player from a personal computer.
3. When connecting a Set-Top-Box with a copy-protect digital out terminal, a high definition picture can be displayed
on the screen in its digital form
OK.
Mar 23, 2011 | Hitachi 57F500 57" Rear Projection...
I get a high pitched noise when in pro tools
I don't know what devices are connected to your audio input ports, sounds like gain is too high on a microphone or guitar or speaker setting too close to your work station, sound like feedback loop.
Nov 02, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
High pitch shrill when flushing
I had the same thing happen to my toilet. The quickest way to resolve the issue is to replace the fill valve.
Jun 15, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
