Question about Sony VAIO Digital Studio PCV-RX560 PC Desktop
Hp wont load up
Hi when i turn on my computer its noy loading up nothing on the monitor and nothing on the key board and i dont know what the problem is computer has not been used in the last 6 months
    Scholar:
  • 131 Answers
Your CMOS battery should have drained. Replace it.
Posted on Jan 03, 2008
6ya staff
SOURCE:
My monitor comes on for 2 seconds and then goes off. If I turn it off then on again it does the same thing. when it comes on I can see my home page. I know the computer is owrking because I hear it when...
when monitors recieve no input the usually turn off or at least turn black.
it is possible that you have the monitor set to the wrong input, or that the cable is not connected correctly at the computer, sometimes there are multiple connections available, especially when there is both an on-board and an additional graphics driver.
if none of those things are the cause of the problem, there is a chance that the monitor is not receiving enough electricity, this can be very dangerous, try unplugging anything using the same wall socket or fuse and trying then.
Apr 15, 2011 | HP Vs17 17" LCD Flat Panel Monitor
I turn on my computer. it starts to boot. then blank screen. nothing. it dosnt load into windows nothing. even my mouase dosnt work but it's on
Turn off computer. Now turn it on, and as it is starting hold down the F8 key. you will hear a beep and ket it go. A set of options will come up and choose Safe Mode with Networking. if it manages to get to windows you are fine.
If not, hit fn key + a key with a smzll monitor (usually one of the F keys at the top, like F5 or F6). It might have been put on display mode and woukd onky show if connected to a projector, tv, or external monitor.
Apr 02, 2011 | HP Computers & Internet
Computer powers up, but nothing boots up firewire light goes out. solutions????
Try continually pressing the F8 key as it starts. You may be able to start it in 'safe mode'.
You haven't got a usb flash drive in one of the usb ports, have you? That can sometimes cause the problem you describe.
Any error messages apperaing on the screen? Don't forget the monitor cable ...
Aug 14, 2010 | E-Machines T6520 PC Desktop
My pc wont even load up. it just gets stuck on the first HP screen with press f9 or f10. it just freezes up, and i dont know what to do. ive tried pressing both of the keys but none work.
try to start it in safe mode, then you can run system restore back to see if this fixes it. when computer loads up and shows the first screen, then push f-8 before it fully loads, this will take you to the safe mode screen, choose safe mode, then when loaded run system restore back to where the problem was ok. if this does not work then I would restore windows from the backup cd. if using safe mode when rebooting, it will change back to normal.
Feb 07, 2010 | HP Mini 1000 Netbook
Lights on but no screen and no motor sound
look for fn key near control,then there is a lcd key on one of the f buttons
hold down together,
if nothing try to plug a desktop monitor in the back of laptop,if you see all is good on monitor
then you need to go further with lcd repair
Jul 21, 2009 | HP Pavilion dv6000z Notebook
Troubleshooting main board.
Three things to look for in service with LCD monitors,
1 bad capacitors
2 Bad transistors for the back light feeds
3 bad ic pulse chips for the Non function circuit
you will not find schematics unless you peruse the patent office records, reverse engineer the circuits and you will have a schematic
when the main chip fails on the vga board its time to buy a new vga video board,
sounds like your board may be suffering a bad IC telling the main chip the power is OK
let me know how it goes.
Dec 29, 2008 | HP w19 19" LCD Monitor
Powers up but black screen shows
1st - Try pressing <Fn> + <BrithnessUP> keys a few times, (on HP <Fn> key is between <Ctrl> key and <Windows> key, <BrightnessUP> key is <F8> key and <BrightnessDown> key is <F7> key. If nothing happens try the 2nd one.
2nd - Plugin external monitor, (type and size doesn't matter). Turn on your laptop. If you can see desktop on the external monitor, your drivers are o.k., The problem is your laptop display, NOT the graphic chip.
Oct 21, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Computer will not load anything
Turning you rmonitor on then your comp my monitor has a delay and if i dont turn it on before i turn my comp on or before i here the little beep noise my comp makes the monitor wont display anything.
Jul 14, 2008 | Systemax AOL Optimized PC (100607) PC...
HP desktop computer will not load...
what os you are loading?
did you purchased it with bundled os/softwares?
Apr 01, 2008 | Computers & Internet
My hp speakers wont work
Sample testing is usually a firmware built into the monitor amplifier ie the monitor is testing itself. you problem possibly lies with the computer sound system. Tell me more about this. Is it an 'On-board' sound card or separate PCI card. You can determine this by looking at the back of the computer- if all the connectors - sound- PS2 and USB are in the same panel - then it is an on-board system. If the sound is separate in one of the card position then it is a PCI card. The possibility is the sound system needs setting up- check your computer paperwork/manual and utilities disk for Audio drivers. Come back with some answers
Jun 23, 2007 | HP P5302M Computer Speakers
Sony VAIO Digital Studio PCV-RX560 PC Desktop Logo
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
