Question about Kenmore 55609 / 55602 / 55604 / 55606 Side by Side Refrigerator
Not cooling at all
I woke up to a smell almost like en electrical fire. I noticed the smell coming from the bottom of the refridgerator. Prior to this happening it seemed everything on both sides was too cold so I had changed the temperature up 1 degree. By the end of the day the friderator was completely not cooling. It runs but everything melted and it does not cool at all.
USE A POWER SURGE PROTECTOR AFTER REPLACING RELAY
Posted on Jan 03, 2008
NEEDS A RELAY IN COMPRESSOR,THEY GO OUT WITH A POWER SURGE,JUST MAKE SURE RELAY IN COMPRESSOR IS HOOKED UP CORRECTLY ,REMOVE COVER FROM BACK THERE IS A SMALL BOX ATTACH TO COMPRESSOR REPALCE
Zenith R57W46
Unplug set and do not plug again---something has burned so there is a risk of fire---unless you are familiar with fixing sets consider having a tech come out or take set to a shop for a estimate.
Jun 16, 2012 | Zenith R57W46 57" Rear Projection...
Think our refridgerator motor went smell of smoke but is still cool will it burn
Check to see if your condensor fan motor is running, should be behind the refrigerator backing plate and close to your compressor. Usually caused by a very dirty condensor unit. You have to vacuum, brush or blow out the condensor coils at least once a year to prevent overheating damage and to save 100.00 to 300.00 a year in electricity. If this is not the problem then let me know if the smell is coming from inside the freezer, refer section, or underneath.
Appliance Specialists
Dec 10, 2009 | GE GSF25XGR Side by Side Refrigerator
I have an Amana refrigerator, bottom freezer, model # ARB2107 AW, MFG:PHR2107AWO This afternoon, we noticed a burning - electrical type smell coming from behind the refrigerator; more specifically from...
Yes the motor should be running and need to be replace to keep the food from spoiling, this will correct the problem however the buning smell is unknown
Melvin
St Louis
Oct 04, 2009 | Amana ARB2217CSL Bottom Freezer...
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Tempature on fridge won't stay @ 38
might be freezing on the evaporator faulty defrost timer or drain is blocked water should run down back bottom tray
May 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 55609 / 55602 / 55604 / 55606 Side by Side Refrigerator Logo
178 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
