Question about Dwin TransVision 3 Plus Multimedia Projector
Bulb or power problem?
Our Dwin is about 4 yrs old and suddenly it powers up for about a second or two then turns itself off...lamp never goes on?? is this what happens when we need to replace the bulb or do you think its another problem??
  • 4 more comments
  • Anonymous Jun 18, 2008
    We've got the same problem and I was wondering the same thing. Time for a new bulb? If so, where do you buy them?
  • Anonymous Nov 03, 2008
    Any Answer
  • Anonymous Dec 28, 2008
    It's not the bulb, it's completely dumb luck when you have the problem and then get it to work...I recommend playing around a little, unplugging the main unit, unplugging the projector, and trying to reset the two...just keep trying...stay persistant...the bulbs are too expensive to just throw money at another bulb.
  • Anonymous Feb 22, 2009
    Same exact scenario here.
  • dbundy68
    dbundy68 Dec 05, 2012
    We have this problem replacing bulb did not fix it still the same problem. Still looking for a solution
  • dbundy68
    Same problem replaced bulb same problem. Still looking for a solution but its not the bulb
You have to order it on the website and they are terrible about getting back to you. Worste customer service in the world. Terrible
Posted on Nov 19, 2008
Just replaced the bulb with a brand new sony bulb. it takes me almost 20 minutes to get the tv to turn on..i turn it on it turns itself off and red light blinks, and i keep trying until it finally powers...
If red light blinks 3 times when tv refuse to power up then check lamp cover that was removed to replace lamp, make sure lamp cover is fixed in its position securely and screw is tight.
Let me know how many times red light is blinking after three second long pause IF it is not blinking 3 times.
Thanks.
Dec 30, 2010 | Sony KDF-50E2000 50" HDTV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
Dwin transvision 4 projector lamp will not light even after changing the bulb. It also looks like Dwin went out of business. Any options to fix?
Call Interlight @ 219-989-0060 and read them what the part # is on the bulb inside the cage. They can probably supply you with the lamp and you simply reuse your cage.
They were able to do this for me
Mar 22, 2009 | Audio Players & Recorders
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Won't power on , just a click and nothing happens
Bad lamp, color wheel or DMD board. Lamp $199, Color Wheel $350 by professional, DMD/light engine $750 by professional
Oct 25, 2007 | Samsung HLN5065W 50" Rear Projection...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Dwin lamp turns off
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Sep 25, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
207 people viewed this question
Top Dwin Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
