Microsoft 10/100 Ethernet MN-120 Network Adapter
Ethernet card not working
shared by 2 users
By Jimmy NY - usenet poster
I'm using a Microsoft Notebook Adapter MN-120, and it works fine with
Windows, but i just installed Red Hat 9.0 and for some reason i cant connect
to the internet. when i go to the Network Device Control it does not show
anything, then i try to add a modem connection and i get the message that
there is no modem recognize.
I'm using a DSL connection
Please help me with this. If is a driver that i need please tell me how to
install it step by step..
thanks
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Dec 02, 2007
does not work
Solution #1
posted on Aug 09, 2005
Thanks for Trying (70)
jessie25
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
A google search under "Microsoft Notebook Adapter MN-120" has revealed
an interesting dialog on the subject here:
http://www.linuxquestions.org/ questions/history/45421
However, before editing the source code for the tulip module, try using
it unedited first:
su to a root prompt then run this command:
modprobe tulip
The tulip driver sourcecode can be obtained from Scyld, here:
ftp://ftp.scyld.com/pub/networ k
Your problem is that you are using a Microsoft product and that company
is ill disposed to providing anything that will help linux users.
The price of network adapters is very low. My suggestion is that you get
an industry standard one.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Ethernet card not working:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Brad
Rating: 0%, 0 votes
In order to save you some headaches, just go online or to a local shop and
buy a Linux compatible NIC. Check the the HCL on redhat.com and then search
for a specific NIC or for a specific NIC chipset that works with RH. I buy
my NICs from a shop here in town for $9. They work fine with Linux.
The reason why you can't detect a modem is because you're using a WinModem.
By definition it wont work with Linux. You need a PCI Hardware modem or a
externel Modem. Again use the HCL on redhat.com & pricewatch.com to find a
modem.
Remember you're coming from the Windows world where almost all hardware sold
in stores works with Windows. Linux is more tight with issues of hardware
compatibility. You should use the HCL, it makes life much easier.
Thank You!
Solution #3
Not Rated (0)
Peter1
Rating: 0%, 0 votes
what is HCL? and remeber i'm using a notebook
Thank You!
Solution #4
Not Rated (0)
Phoebe
Rating: 0%, 0 votes
Whoops sorry I misread that you are using a notebook, I thought it was a
desktop.
Anyway, the HCL stands for Hardware Compatibility List. Self explanatory.
I can't help you with PCMCIA stuff, I don't use notebooks at all.
Thank You!
Can you Help with these Network Adapters problems?
Network Adapters
my belking usb adapter has stopped working again. I bought...
Network Adapters
hi we have set up the linksy router & it works fine...
Network Adapters
I can't seem to connect using the wireless connection. It...
Network Adapters
This has hindered me from using and accessing the...
Microsoft 10/100 Ethernet MN-120 Network...
toshiba wireless me me i
Loading problems.
Repair Service
Find Network Adapter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
