Question about Kenmore 2303x Top Load Washer
My Kenmore Elite Model 110 23032102 sometimes will not wring the clothes dry
My washing machine is not even five years old yet and it doesn't always spin the clothes dry. My husband and I thought it was the gear case because we found oil residue under the machine. He also replaced the motor coupler just to be on the safe side. We still have the problem.
I have also read it could also be a problem in the timer, the spin solenoid, the lid switch or the basket drive mechanism. Do you know if this model machine has common problems in any of these areas and if so how can I troubleshoot?
Thanks so much,
Tayalex
  • tayalex Jan 04, 2008
    After watching the washing machine cycle through a typical wash but
    without clothes, I observed a number of things. First of all, both
    times the water is to drain from the tub it does so completely and
    within a minute. I also noticed that when the basket is supposed to
    spin and just after the water drains, it doesn't spin at all even
    though I hear a noise which sounds like it should be spinning. The
    other two scenarios during this wash is that it will finally start
    spinning after the rinse but that toward the end of the spin it slows
    down considerably and then eventually stops spinning about two minutes
    before the complete cycle is finished.
    In addition to this question, I need clarification. I thought the motor
    coupler replaced the belts from the older models. Much of the
    literature that I have read on the subject mentions belts in the basket
    drive mechanism. Could this be my problem and if so how can I verify.
    Thanks so much for your help.
    Sincerely,
    Tayalex
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Before you do anything else...have you fully checked the pump system...thats starting at the pump to the termination of the drain hose. Coins and objects can cause partcial blockage which can cause the symptoms you described. Let me know how you get on.
Posted on Jan 03, 2008
  • Rene Jan 04, 2008
    I myself have not got specific manuals....yet.... just in the process.
    You should see a belt if its there. What you say sounds right.
    Sounds like the mechanical is working ok, Possible that its electrical. Some models have a seperate controller for control of the motor...reversing module. when faulty they can cause various problems.
    So check your program settings. past that the contoller..(s)is..are...not sending the correct signal to the motor.
    the reason for this explanation is you said it spun briefly on rinse
Kenmore elite HE4 moldy smell
keep door open after you use it....keep them open until you use it again.... door can be opened just a little, but can not be closed
let machine work once with highest temperature without anything inside..... with little detergent you always use.....to wash away that smell...
if you keep it closed, then moisture will remain in and provide good environment to bacteria causing black mold to live there.....
you can remove that only mechanically..... take some old dry dampcloth and wipe it away.... it will take some time and hard work.:)
Jan 13, 2014 | Kenmore Elite 45986 Front Load Washer
Softener reservoir doesn't drain when washing. Kenmore Elite about one and a half years old.
Possible blocking on the drain from the tray, remove the accumulated softener from the dispenser , clean and check the drain line. It can be blocked with residue or dirt.
Mar 17, 2013 | Washing Machines
I have a Kenmore Elite top-loading washer, the spin cycle doesn't wring out the clothes dry. Is it worth repairing or should I just replace the unit?
the problem a lot of times when that happens is a broken motor coupler and a coupler is easy and cheap to replace. This video shows how to replace the coupler so watch it to see how to get to coupler to see if its broken.
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5457341501&kw=washing%20machine%20coupler
I hope this helps
Gene
Aug 03, 2011 | Washing Machines
Kenmore elite dryer is not generating heat to dry clothes. The machine is less than 4 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 01, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine fault
lg trom showing E and on display won't drain
Mar 26, 2008 | Washing Machines
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Kenmore Elite top load set
fabric softener will leave oily looking stains on certain fabric. oil stains will not wash out.i do not recommend using softener in washers it gums up everything!
Nov 03, 2007 | Kenmore 22422 Top Load Washer
Kenmore 2303x Top Load Washer Logo
776 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
