Question about Gateway GT4022 PC Desktop
Turns on, then shuts down before anything shows on monitor
The computer shuts down almost as soon as it starts up. Then it will not start up again until I unplug it and start over. Each time, it will just shut down again. I took the side panel off and watched the LEDs on the Mother board. A green light stays on near the CPU. When I turn it on, a red light flashes for an instant at the bottom of the board, near the board slots. I tried a different power supply with no change. I tried unplugging all the power cables to the drives with no change. I unplugged and reseated the memory chip and the CPU with no change. I don't have another CPU or memory chip of the correct type to try in it. Any suggestions? I have read all the solutions listed for the GT4022 PC with the exception of the cmos battery.  I would like to know if the foxconn NF4uk8AA-8E (Newegg.com) is an equal replacement motherboard part.  If it is not, please suggest an alternative.  Thank you, nj
    Sergeant:
  • 263 Answers
You have to change prossesor is overheating
Posted on Jan 03, 2008
  • 2,427 Answers
Well i wont suggest you change your mother board alonne cause its your processor thats damaged.
Something caused the processor to damage and i believe its from the main board thats why your not getting a beeping alert(i didnt see you mention any) a continout beep means the processor isnt initilazing and a 3 beep pause means its memory.
You should change both processor and board.
To determin compatable boards all you need is your processor socket type. for example if your processor is a amd 754 socket, then any 754 socket boards will work with your processor.
OK NOW FOR SOMETHING YOU CAN TRY
1.) unplug the power supply from the main board
2.) remove the cmos battery and memory
3.) clear the cmos by switiching the jumper at jp1 for 10 seconds then switching it back
4.) plug power supply back into the main board and replace the battery leaving the memory out.
5.) ensure you have the mainboard speeker(beeper) connected
6.) turn on the system without the memory in it and listen for any beeping sounds
IF YOU GET THE BEEPING SOUN CONTINE HERE
7.) shut down and put in memory
8.) it should boot and work
IF YOU DID NOT
7) shut down by unplugging the computer
8.) remove the processor
9.) clear the cmos again
10.) replace the processor
11.) clear the cmos again
12) boot without the meory and listen for the beeping sound
If you get it turn of the computer and replace rams and it should work.
NB jp1 is located near the battery look on your manual for it or look for a 3pin jumper near the battery
it has 3 pins, the jmp should be on 1 and 2
put it on 2 and 3 to clear it then put it back on 1 and 2
IF THE ABOVE DONT WORK AND YOU DONT HAVE AXCESS TO ANOTHER COMPUTER TO TEST YOUR PROCESSOR I RECOMMEND CHANGING BOTH BOARD AND PROCESSOR
    Sergeant:
    Champion:
  • 347 Answers
Hi m5mm, what kind of Operating system are you using?
  • 3 more comments
  • Santiago Vallejo
    Santiago Vallejo Jan 03, 2008
    When exactly does the computer shuts off? after the "loading windows" appear? Once you can see the desktop? Can you see the white letters at the start up or does the computer shut down before the white letters?
  • Santiago Vallejo
    Another common simptom of computers shuting down is when the fan isnt working properly. The fan keeps it form over heating, but if the fan stops (by a malfunction, dust or dirt) the computer will shut off.
    I recomend you before opening it to get a hand-fan and try to blow the computer from its back to clear some dust, if the problem continues, open it and before doing anything else, check how clean/dirty is the fan.
    If you can get to the screen of "loading windows" and then it freezes and restart, or shut down, It can be a Virus,
    If you have that kind of virus, it will start deleting files each time you try to turn on the computer, then the computer will shut off to prevent the virus doing more damage.
  • Santiago Vallejo
    _______________
    NJ, remember to rate us once we have solved your problem
  • Santiago Vallejo
    Nj, if you could tell me how far can you get before your computer shuts of, i can help you further more.
  • Santiago Vallejo
    Hi again Nj
    If you are sure the problem is in your Motherboard, then you might go on and buy another one online.
    newegg.com is a good site, but i will recomendo you to buy it in ebay.
    I think its safer, and it gives more variety,
    If you have an special Motherboard in mind for your computer or you want to search many brands before buying one, Here you can go to a good webpages that have many good Motheroboard brands, their phone number, and the website adress
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Computer required restarting due to problems with mouse. Once computer was restarted gateway monitor would not work
Not enough information. Please describe any monitor activity when
you turn it on, do this while the computer is still off, unplug monitor, then
plug back in. It should start automatically, then show the gateway logo, then
go blank for several seconds, then show no input signal box, then shut down on its
own. If it fails to do this it is probably that the power printed circuit board
is failing, not delivering the proper power to the main board and/or the back
lamps. One can have this board repaired inexpensively by a qualified electronic
technician.
Email me at Sprint6@zoominternet.net
and we may be able to get your unit working properly again.
Have it repaired soon to avoid additional component failures
Dec 17, 2010 | Gateway FPD1975W 19" LCD Monitor
I hooked my monitor to my computer but it shows a monitor with a ? on it. its because the resolution is to high but i cant change it now.
shut down the computer and start it again. just press and hold the start buuton for few second and the pc will turn off. then start it again
Sep 12, 2010 | Computers & Internet
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
LCD Shuts down
The monitor screen may be OK, but the monitor electronics are not. YOu state that the comuter works fine with a different monitor. That leaves out the video card. If you reall ywant confirmation of a bad  monitor, Try it on another computer ansdI am willing to bet that it  will again shut off.  Take it to a shop for repair or replace it.
Feb 01, 2009 | X2Gen MG19MY 19" LCD Monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Jul 25, 2008 | Compaq Presario S5100NX (E120866) PC...
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Jun 14, 2008 | Computers & Internet
Gateway GT4022 PC Desktop Logo
282 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
