Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Problems with the Compact Flash card
I removed the CF card after having taken many pictures. Then I reinserted the card and had some problems. Now the camera is saying that the card is bad, replace it. I did so and get the same error. This is a new camera and the first time I have used it. I am sick thinking something is seriously wrong with the camera. Can anyone help?
  • 2 more comments
  • Anonymous Jan 04, 2008
    Wow. I have the same problem. I took about 80 pics and downloaded to my computer. Then I put the card back in my xti and it tells me the cf card is bad and try another one.
  • cobra56889 Jan 06, 2008
    same as the others but if I try to format the card in the camera it gives me a err code 99.
  • Anonymous Jan 07, 2008
    I used two different brands; namely, a transcend and a SanDisk. . I think it is a bad design with the camera not the card.It must have very fragile pins, so that any wiggling or whatever when inserting the card into the camera, can result in a problem. If I had paid more attention to the concept and design of the compact flash cards, in that it uses "pins" to make contact, I would have opted for another brand of camera.
    I believe that we will all have problems getting anywhere with this...probably we are going to have to have the camera repaired. $$$$
    I thought of that and did check the pins once. I will check again. How could the pins bend so easily? You can't force the card in and it only fits in one direction. Again, this is scary if bending a pin can happen so easily.
    Problem Solver:
  • 8 Answers
With some flavors of windows, you may notice this error. Solution is to format the card while in the card reader using windows. Then insert the card in the Camera and format again. It should work.
Posted on Mar 26, 2008
You have a bent pin. look inside and see.
good luck
Posted on Jan 07, 2008
    Problem Solver:
  • 5 Answers
Maybe it is from a bad batch...could you tell us the brand like Sandisk,Lexar.PNY etc?
Posted on Jan 06, 2008
    I have the sandisk ultra II right now and last night i inserted the card taking care not to push it in at all.All i did was slide in the card and no additional force added and closed the door.Switched on and saw the card read by camera.I think it is a very sensitive pin to hole assembly,yikes and thanks for the warning!
6ya staff
SOURCE:
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Chart details not appearing after removal.
Same problem I had. After resetting unit and checking CF on another unit, Raymarine tech. said, the reader is not working. All pins seems to be OK on first look. I opened unit by removing several screws in front, gasket and the whole chassis from the case. Simple repositioning of pushed down pins from inside into the Compact Flash corrected contact problem of reader. Since then, I never removed CF. It seemed, after several reinsertions of CF, I pushed down two pins in CF slot.
Jul 26, 2010 | Raymarine C120 GPS Receiver
Can not take pictures
The R1 uses both Memory stick and Compact Flash... is it possible that you have a memory stick installed and the switch set to compact flash"
the switch is on the lower right side on the back of the camera. it has two positions Compact flash is "CF" and memory stick is a little memory stick logo.
Apr 07, 2010 | Sony Cyber-Shot DSC-R1 Digital Camera
Digital frame won't read memory cards
Did you format the card before trying to use it?
Dec 30, 2009 | Polaroid T831 Digital Camera
Err cf have changed compact flash cards. every
check deep inside the card slot to see if you have any bent pins. They can often be straightened out with a thin screwdriver.
Sep 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Compact Flash card unreadable by computer
Hi Craig Click,
CF cards are flash memory based technology and as such have the practical limitation of 500-1000 overwrite cycles before they can become unstable. I would suggest you have a card(s) which are reaching this stage in its life. Beg, borrow or buy another card to see if your luck changes....I suspect it will.
Good luck
Kiwi-Mark
Jan 06, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
CF Excessive Power
Nikons and Fujis keep the CF slot powered, and "poll" it every now and then to see if a card has been removed or inserted. So yes, a camera may drain batteries much faster with a CF card than it does with an XD. But if it really does do this, then someone at Fuji deserves to be on the street, looking for a new job. Polling a card every few seconds does not have to be a traumatic experience to the camera. A Nikon can sleep for months, and not show appreciable battery drain. After what I've seen in the horribly slow CF write times of the S3, and the large artificial difference in write times between CF and xD on that camera, I'd say someone (or several "someones") at Fuji is doing everything in their power to make CF look bad and steer people into xD.
Sep 12, 2005 | Fuji FinePix S7000 Digital Camera
Compact Flash card compatiblity
I don’t know why you PDA can not read your card but I found some infrmations about parts which are compatible with e800. As far as I know this types are compatible with e800. Compact Flash Memory Card 1GB (PX1076E-1NME) Compact Flash Memory Card 512MB (PX1075E-1NME)-Type I Compact Flash Memory Card 256MB (PX1074E-1NME)-Type I
Sep 08, 2005 | Toshiba e800 Pocket PC
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
69 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
