Question about Nikon D40x Digital Camera
D40 Flash didn't work
Had it for about 1 mo and the flash would not pop up. I popped it up on my own and now it works fine and pops up on its own. Should I still take it back or will it be ok now. Why would it not pop up before? It clicked but never popped up.
Thanks
  • Anonymous Jan 06, 2008
    It now pops up but doesn't fire.
  • Mikidog Jan 09, 2008
    My Nikon D40x builtin flash pops up but does not fire in any mode. I have had the camera approx 2 months and the flash worked the first time but not since. I have not dropped it or abused it in any way. Solution?
    President:
  • 4,402 Answers
Seems to me that this is some kind of fault with the camera design\
i would get a different model
Posted on Jan 09, 2008
My D40 rolled off my couch and broke my flash. After watching a video, I opened up the flash and got the flash working, but now the flash won't pop up... After messing with multiple pieces (while reading...
Check to make sure the flash up switch on the side of the flash (the switch you see where the wires go through when you remove the flash top) is not under the activation rod on the pivot, the pivot is not pushed in, or the activation rod is not broken off. The switch should close when the flash goes up and be open when it is down. A lot of times you see the top contact stuck under the activation rod. Also check the continuity of the two thin switch wires as sometimes they are borken inside by impact
Sep 01, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash won't pop up
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Auto flash wont work
did it pop up automatically or did you pop it manually? if it popped up by itself then the flash unfortunately is probably dead, since on automatic, it won't pop unless it's going to fire. If you popped it manually then - the camera doesn't think that the flash is necessary for the conditions that you're shooting in.
Oct 21, 2009 | Nikon Cameras
Flash not popping up - did i push something?
Make sure you're not shooting on no-flash auto mode. Also, in P, A, and M modes you'll have to press the flash button on the side of the camera by the lens mount in order for the flash to pop up. If it's not popping on regular auto mode, make sure you don't have it disabled in the menu.
Jun 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 built-in flash...
Hi and thanks for coming to FixYa.
You can set the parameters for the manual flash in the Custom Settings Menu. Select Full to set the manual flash adjustments.
Hope this helps. Let me know if you have any questions in a comment.
Rob
Feb 27, 2009 | Nikon D40 Digital Camera
Nikon D 40 flash pops up but does not flash.
Is the flash on Off mode? Is the battery fully charged? If not, charge the battery and try again.
Dec 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40 will not flash
The lightning bolt icon in viewfinder blinks when flash is not ready, this can happen if flash doesnt pop up all the way, or if flash strobe tube is bad.
May 16, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40 flash won't fire
If lightning bolt icon is blinking in viewfinder, flash is not ready. Either flash isnt popped up all the way or flash strobe tube is bad.
May 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Pop-up flash
make sure after popping up the flash, you didn't change the mode into "no flash" mode....an easy way to check is put the flash back down, then proceed to take another photo. If the flash pops up again but did not flash, you have a faulty camera (assuming battery level is at least until the 1/3 mark).
Dec 26, 2007 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D40x Digital Camera Logo
42 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
