Question about GE Spacemaker JVM1640SJ Microwave Oven
Ringing noise I have a 6 month old fridge that is making a high pitched ringing noise that is driving me batty! Help!
  • 619 Answers
Replace thje diode cause noise , the magnetron are shortening need to replace magnetron /check the old m-=oven same brand and parts and replaceit.
Posted on Jan 03, 2008
Microwave makes noise when on
All microwaves make some noise when running. Cooling fans, exhaust fans, turntable motor, transformer, and magnetron all make noise. I assume you mean some unusual noise. I need to know more about what kind of noise it is - a loud roar, a rattling sound, a high-pitch squealing sound, a "clunk-clunk" sound or what? By the way, a "klunk-klunk" sound is frequently caused by small debris stuck to the wheels of the turntable support tray. Try cleaning those wheels and the track they roll in.
Oct 21, 2014 | Whirlpool Accuwave Microwave Oven
Why does my fridge (whirlpool wren 58sl) sound like a helicopter on my kitchen, help, its only a month old
First of all being a month Old you have the privilege to get the warranty for a free work. But you can attempt to see if there is any vibration of the plastics that sympathetically vibrate with the compressor motor. If so you will need to use some damper double side sticker pads to close the gaps in-the plastics to shut off the noise. If however the noise is within the compressor then you must claim for service.
Oct 30, 2010 | Microwave Ovens
I have a JES1142 which I purchased only one month ago. The turning plate rotates both clockwise and counter clockwise. When it rotates counterclockwise it makes a grinding sound. Why does it rotate bot...
It's normal for the motor to turn both ways, that's because of how the motor is made. As for the grinding noise, there's no reason the motor itself would make more noise turning one direction than in the other. The noise might be coming from the roller ring under the glass turntable. One of its wheels might be binding when it tries to turn counterclockwise.
Here's a test. Take the glass tray and roller ring out of the oven. Put a microwave-safe container with a cup or so of water in the oven and start it. Stop the oven and start it again, and the motor should turn the other way. If not, repeat this until you've seen the plastic coupling turn both directions. Note whether you still hear the noise as the motor turns each way. If you do, then there is something wrong with the motor and it should be replaced. If not, the noise is coming from the roller.
In either case, if the oven is truly only a month old it's still under warranty. Since you are concerned about the noise and are worried that the oven is defective, contact the store where you purchased it and see if they will exchange it or take it in for service. If the store can't help you, refer to the owner's manual for the service procedure to follow.
Hope this helps. Thanks for using Fixya!
Feb 13, 2010 | GE Microwave Ovens
Buzzing sound when the vent fan is turned on. Sound is high pitched, and I can't tell if it's coming from the top or bottom. Any suggestions?
I don't know if this applies in your case but I have had fans with metal blades that would resonate with a high pitched ringing sound. It may also be that a blade is slightly contacting a metalic mesh filter cartridge.
Jun 25, 2009 | GE JVM1860 Microwave Oven
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
Makes loud noise when running like a high pitched noise
You have a bad magnetron. Just replace the unit. It will cost more to fix than to buy a new one. There are great deals on new microwaves now.
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium oven (6 y.o.), has hot spots, makes unusual noise
The drive to the carousel is broken...and what you hear is the drive trying hitting the bottom of drive shaft* (cheaper to replace then fix)
Dec 11, 2008 | GE Advantium 120 Convection/Microwave Oven
Ringing noise from refrigerator
It's probably a dry bearing on either the compressor or the fan in the freezer. The evaporator, I believe it's called.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
If it's under a year old, it's probably in warranty. You can get warranty info & find a local authorized servicer from there, too.
To order Goldstar / L.G. parts for a do it yourself repair, visit Vance Baldwin Electronics. You'll probably have to call them.
Dec 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try
Dec 07, 2007 | Kenmore 62622 Microwave Oven
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
GE Spacemaker JVM1640SJ Microwave Oven Logo
326 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
