Question about Euro-Pro Steam Generator EP8001 Iron
No steam Unit is about 3-4 years old. No steam coming out of iron. Steam light does'nt come on. The iron will heat up. Iron light comes on.
  • 7 more comments
  • dardy Apr 22, 2008
    I also have the steam generator model EP8001 with the same problem as posted in January. The steam nor light works, but the iron does heat.
  • flipdaddy Jun 18, 2008
    after pluging into outlet no light appears until 5 minutes later. still no heat.
    Once after pluging and unpluging the greea light appeared and it began to heat.
    added water to no avail. Just the apearance of the RED LIGHT and no heat.
    Even after jiggling the plug.
    checked for break in cord but cord was okay.
    the model isan B&D Steam advantage AS185 type 1 8j06 flat iron
  • lolai Jun 19, 2008
    Yes, my unit is about 5 yrs. old, the iron is becoming detatched from the handle portion, it heats up quite a bit & today I've decided that I'm stopping using it.
  • nallen Jul 09, 2008
    my iron is doing the same thing - I've had it since 2001. I think it is the switch that's bad - can't find anyplace that will repair it. \
  • markie1 Aug 05, 2008
    i have the same problem but with a different model.. the EP8005 i have not been successful in finding anyone who has parts, but i did locate the problem for our unit. the ceramic thermostat was corroded and a wire broken off.
  • Anonymous Nov 02, 2008
    I OWN
  • rickporter1 Nov 02, 2008
    I also own the same unit with the identical problem relating to the steam switch and no steam; is there an inexpensive solution or is replacement of the unit my only relief?
  • Anonymous Mar 17, 2014
    Making a noise and no steam coming out
  • Anonymous Mar 30, 2014
    No steam comes out, a blue light keeps flashing
Contact A2A Consulting at 1-888-830-3563; they can probably fix the unit for you.
Posted on Feb 03, 2009
At a repair center they quoted me $55 for the repair, while I bought a new switch (not identical like the original) for $1.50 and a friend repaired it for free.
Posted on Oct 28, 2008
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
Black & Decker Steam Xpress AS250 Iron with Auto Shut-off: my iron won't heat up. the green light comes on b...
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
May 18, 2010 | Black & Decker Steam Xpress AS250 Iron...
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
No spray
Return it to the purchaser and they will replace it or return to the manufacturer. Be sure to take your reciept with you
Sep 16, 2009 | Euro-Pro Steam Generator EP8001 Iron
B & D Light and Easy Steam/Regular Iron
if you have a multimeter and know how to use it get that tool ! if not , buy another one.
Sep 17, 2007 | Black & Decker D2030 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
823 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
