Question about EliteGroup ECS 755-A2 Motherboard
What's going on?
I have recently endeavored on a pc build for my smaller siblings. I purchased an ECS 755-A2 Motherboard with all the essentials to go with. After everything is plugged in and the power button is turned on, the only thing the stupid thing does is beep and nothing shows up on the screen. What is going on? I've tried everything I know, I have even replaced HD, CPU, Graphics Card. The only thing I have not replaced is the power supply. Could that possibly be my problem?
  • Anonymous Jan 03, 2008
    It is inserted properly and I tried it in both slots. What do you mean by: or might be fault with the memory card ?
  • 656 Answers
Please check ur memory card it might not be inserted in the slot properly or might be fault with the memory card
Posted on Jan 03, 2008
6ya staff
SOURCE:
Where can I fine manual for 755-A2 I went to EliteGroup www. No luck. Can you please HELP. Thank You
Try this:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=381&DetailName=Feature&MenuID=1&LanID=0
Sep 26, 2010 | EliteGroup ECS 755-A2 Motherboard
ECS 755-A2 won't go past BIOS Screen
do you have the setup cd that came with the board. the drivers probably need to be installed. if so run the disk and install the drivers and it will work.
Mar 13, 2009 | EliteGroup ECS 755-A2 Motherboard
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
ECS 755-A2 USB 2.0 no working
The best thing to do is uninstall the USB drivers on the machine and download off ECS the latest firmware and install.
Jan 07, 2009 | EliteGroup ECS 755-A2 Motherboard
The usb ports and the pci slots do not work
Yes, this can still be fix, try first to run the setup CD for your ECS motherboard to reinstall the driver for those devices...if still not fix you may need to download the latest driver for your motherboard from ECS web site and update the driver for those devices..
Oct 14, 2008 | EliteGroup ECS 755-A2 Motherboard
Motherboard 755-a2
I go Why can't I install Windows XP on my S-ATA HDD by SiS964? A: You have to copy the driver paired with the motherboard package into a floppy disc before you installing WinXP or Windows 2000 on your system, and follow the notice showed on the screen to insert the floopy disc. The system will grab the needed driver from the disc to finish the installation of S-ATA HDD automatically.
Because SiS964 was announced before than Windows XP and WinXP therefore it can't recognize it. If you want to install a whole new WinXP (or Windows 2000) on S-ATA HDD by SiS964, you need to copy the necessary driver from the directory named floopy image on your driver CD to one floopy disc. When you begin to install OS, follows the instruction to put your disc into floopy drive. After this, you will keep on installing your WinXP smoothly. If you use P-ATA HDD, you don't need to do like this.
t this off the sis.com web site what does it all mean.
Sep 03, 2008 | EliteGroup ECS 755-A2 Motherboard
ECS 755 A2- PC wont boot up with my X-FI sound card Extreme Gamer all i get is a black screen when turning pc with my sound card atached to mobo.
on most motherboards you have to install soundcards into the top or no 1 PCI slot if you dont it wont boot up. a lot of people install thier modem in that slot if yours is it will have to be moved to the bottom slot, this should fix your problem.
Jan 10, 2008 | EliteGroup ECS 755-A2 Motherboard
System booth
the ram memory might not be compatible from your motherboard, you should have find it on the list of your motherboard manual. the manual have the list of memory cards' qualified brand. likewise, try to install this to ther slot if the problem still occurs then you may return to your vendor and inform them about the specs and kind of your motherboard and the problem you are encountering so that they will give you the right memory card to use. you can also ugrade your bios thru the internet so that you don't need to return this item.
Dec 13, 2007 | EliteGroup 755-A (ECS 755-A) Motherboard
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
EliteGroup ECS 755-A2 Motherboard Logo
100 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Ekse
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
