BenQ FP731  17
Dell d600 power issues
shared by 2 users
posted by alxz on Jan 03, 2008
My dell D600 cannot recognize the power supply, so it only runs at a safe speed (600Mhz) and it won't charge the battery.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Jun 18, 2008
my problem is also same ,but I think I have done a wrong thing I contacted middle pin and other contact so I think the data system is destroyed,Please tell me what do
Solution #1
posted on Apr 09, 2008
Not Rated (0)
Mark_Webber
Rank:Guru Guru
Rating: 87%, 265 votes
The problem is in either the power lead from your powerpack or in the connector on the motherboard itself.
In this case I would say it's in the powerpack.
Dell use a smart power supply system that talks to the laptop to say if it is a genuine part or not.
If you look at the plug you will notice something strange about it.
There are actually 3 layers in there (well sort of)
You have the outer layer, then inside you will see a pin. There is another layer that is wrapping around the inside of the plug that is a mirror of the outer layer.
The wire that connects to the centre pin is not power, but the smart pin. The wire can easily break off that pin and just sit inside the cable.
Try it with a known good adaptor, or just get another one.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on dell d600 power issues:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
it was working great and 1 day it just went black it is...
Monitors
Left work on Wednesday, November 26 to find my montior not...
Monitors
no constant hot water from baxi 105e
BenQ FP731 (Silver) 17" LCD Monitor
monitor has vga and dvi plugins,on screen display is short...
how do i put a battery in a benq portable mouse for...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
