Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Electric Dryer - replace belt
I installed a new belt on a Maytag Electric Dryer. Everything seemed to work as described in the "fix it yourself" manual. However, the path of the belt doesn't seem right. The belt goes around the drum then around the motor spindle then over the idler pulley and then rests on a 1" wide metal bar. The bar provides tension on the belt.
I just bought the dryer two months ago and the belt already broke. I think the belt broke becuase of the metal piece it rubs on. See photo below.
I can't see an alternate path for the belt. Any tips would be appreciated.
Keith Mast
  • 2 more comments
  • keithmast Jan 03, 2008
    If I move the belt above the metal, there seems to be too much slack in the belt. However, I did not turn the dryer on with the belt on top. Perhaps it will tighten when the motor is "on" and the drum is turning?
    Thanks.
    Keith
    PS I bought the dryer "used." It is probably several years old.
    In the end, Oceti was right. I re-routed the belt above and everything seems to work fine.
  • Anonymous Aug 05, 2008
    belt installation diagram
  • LILOSAGE Mar 15, 2009
    iI replaced a broken belt, it turned the drum and then stopped working, it runs its just not turning the drum now
  • 51 Answers
The belt needs to be above the metal. Otherwise the repair looks good. Easy fix. Thanks for the pic.
Oceti
Posted on Jan 03, 2008
Dryer just stopped wont turn
More than likely a broken belt. A fairly easy fix. Disconnect Dryer electric by shutting off the breaker. Then remove the front panel that surrounds the door. There are ususally a couple of screws on the bottom and you have to pot the top. Get a belt off the net or from a appliance dealer. The belt slips around the drum over the motor shaft and on a tension Idler wheel. Pop is back together and you good to go. Try checking You Tube and see if there is a video on dryer belt replacement. Good luck! :)
Oct 07, 2012 | Maytag MDE308DAYW Electric Dryer
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
Installing a belt on a maytag dryer the belt seem to be too big what's the solution
you probably don't have it strung right thru the idler pulley by the motor, thats if you have the right length belt to start with,measure it with the old one to be sure
Oct 26, 2009 | Maytag SDE5401AYW Electric Dryer
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer:attached belt as per directions,but is still loose,the pulley seems to not give enough tension
You can verify your belt installation by going to repairclinic.com. Click on the "Repair Help" link at the top of the page, then locate the "Dryer Belt Diagrams" link under Special Features. Refer to Diagram E under the Maytag heading. If you say you have the belt installed correctly, make sure the tension spring is still installed. I hope this helps you.
Jun 27, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Belt replacement on an electrical maytag dryer
hi. thanks for the question. to replace belt . lift up top, remove front panel, slip belt over drum. reinstall front and top, and clean all lint . pull dryer from wall ,remove back panel . motor on right, idler pulley on left, pull belt through idler and to your motor.
May 13, 2009 | Maytag PYE2300AY Electric Dryer
New dryer belt is rubbing top of idler arm spring
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page look for "Dryer Belt Diagrams" under the Special Features section. There is an extensive list of dryer belt diagram illustrations available that you can print out. Maytag is listed. Hope this helps you.
Nov 11, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
4,150 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
