Samsung RS2630WW Side by Side Refrigerator
Problem for Samsung RS2630WW Side by Side Refrigerator
I have a GE side by side (TFX25JRYAWW) and it is
By mrogers71718 on Nov 01, 2009
I have a GE side by side (TFX25JRYAWW) and it is 13 years old. It seems the fan will work sometimes. If it is stopped and I spin it, then it will continue to work and spin for a couple of weeks. I've read a lot of other similar problems, but I don't know if it the problem is the fan or the circuit board that controls the fan. Suggestions please! :-)
Solution #1
posted on Nov 01, 2009
Not Rated)
hohox5
Rank: Wiz
Rating: 82%, 507 votes
before replacing fan remove and oil shaft lightly and work blade back and forth this may extend the fan life the bearings are probably worn or dry if fan still stiff upon turning replace
Was this helpful?
Yes
No
Solution #2
Not Rated)
jackfrost555
Rank: Guru  Refrigerators  Expert
Rating: 92%, 131 votes
If you can start it by turning it manually, and it starts, then the only obvious solution is replacing the motor, since it's obvious power is getting to the motor, and if so should start on it's own.
Was this helpful?
Yes
No
Popular Solutions for Samsung RS2630WW Side by Side
Questions and Unsolved Problems for Samsung RS2630WW Side by Side
Do you recommend Samsung RS2630WW Side by Side Refrigerator?
Answer
Answer
Everything thing works great other than it stopped cooling this summer. It is only 3-4 years old... (More)
Answer
Samsung RS2630WW compressor not working, took apart and reassambled. Compressor worked for a short... (More)
Answer
Samsung RS2630ww, stoped working. The green light on the electronic panel that indicates ice size... (More)
Answer
Our Samsung RS2630WW is making a squeaking sound. Specifically, I know it is the fan due to the fact... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Las Vegas, NV
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
