PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
Acer computer is frozen on
By ince_c on Nov 01, 2009
acer computer is frozen on screen which reads press f12 or del to enter setup. when computer comes on it does not beep so i cannot use keyboard all the lights on the keyboard aare off. HELP!!
Solution #1
posted on Nov 01, 2009
Very Helpful)
Dageezer
Rank: Guru  Computer Hardware  Expert
Rating: 89%, 983 votes
From the description you are giving, it appears that the system is not detecting a bootable hard disk drive. Hold the power button on the system till it powers off. once system is off, try the following:
  1. Ensure no floppy diskette is in the A: if system has a floppy drive
  2. Disconnect all external items (Printer, scanner, network connection) leave only video and keyboard connected to system.
  3. Try powering system on again
If the system gives the same message, try rebooting and pressing F12 ONCE at the ACER screen and see if you can get a 1 time boot menu. If you can get the boot menu, select CD-ROM, and put you WINDOWS CD in the optical drive, see if system will boot to the CD. If you can, then at the first prompt, press R to enter recovery console, and see if you can run the command CHKDSK /R (then press enter)
If chkdsk runs, then reboot and see if the error has gone away. IF you cannot run CHKDSK then the hard disk drive has likely failed and will need replacement.
Comments:
Nov 02, 2009
- If the system will not boot to a CD with the HDD removed, then you appear to have a motherboard failure.
If you detail the results of the suggestions I made (What happened after each attempt) then I might be able to give a more definite answer.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" this is not working. computer is not responding to any solution " - ince_c
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
What is the best NAS for about $300 (+, - $100)? I was looking at... (More)
Answer
sx2800 how is it compared to other brands its size
Answer
well, i opened my computer, it goes well until the windows logo part, and instead of the password... (More)
Answer
No signle to the Monitor, I reset the CMOS by changing the jumber location to 1 & 2 for 1... (More)
Answer
When I plug this computer in a green light flashes in front and back. When I remove the 24 pin plug... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(168) 454-4153
QABastards
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
