Jetway K8M8MS Motherboard
Video
shared by 2 users
posted by ashkorewd on Jan 03, 2008
I have this motherboard, and everytime I have had to move the computer, or disconnect the power, the video stops working for several hours to weeks on end. What is the problem? I've tested the monitor, and it works on every other computer I have tested.
What could be the problem?
Comment posted on Jan 04, 2008
I checked all that. The onboard video is firmly connected, the monitor cables are good (the monitor works every time with my other systems) and there hasn't been much of an explaination for the issues i'm running into. I have taken out the processor and replaced it again, checking all the pins there, and then the system started running. But I have to do that every time I unplug it (i'm moving it out of my testing area and to my desk) and it's rather difficult that way. I'm worried that it'll happen in a power outage as well.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by gpageorge on Jun 15, 2008
Tried onboard video and ati card; still no video with k8m8ms.
Best Solution
posted on Jan 03, 2008
Helpful (85)
Re5cue911
Rank:Wiz Wiz
Rating: 87%, 50 votes
If you feel comfortable inside of a computer, open the case, take out and put back in the video card, making sure that it's seated firmly in the AGP or PCI slot. If there's no video card (onboard video), check to see if the connection on the motherboard is getting loose.
Other than that, check the cable at the back of the monitor, and the pins at the end of the cable. It's possible that a pin is bent/damaged in the connector, and the monitor only works when the cable is in the right position and you hold your breath and there's no wind....
Let us know what you find, and please leave a rating if you find this helpful.
Rating Locked! (?) ashkorewd has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Video:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
SiS 760 Display Adapter not functioning. I also have...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
