Standard Televisions
Generic problem for all Standard Televisions
Tv problem
posted by snoopdog970 on Jan 03, 2008
I have a mitsubishi tv..ck 31302. i have owned this tv for several years. i took it out of service 4 years ago due i bought a 65 inch big screen. when i put it away it was working fine. i pulled it out to use it in my daughters room and all i get when i turn it on is a blue line across the middle. thanks for help.
Comment posted on Jan 03, 2008
so is this problem something i need to take it to a tv repair and have done or would it be cheaper to by my 2 year old a new tv....
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
sedonix
Rank:Guru Guru
Rating: 86%, 497 votes
The vertical sweep circuit has failed.
Can't say that its because of being stored, but it is a common problem on CRT TV's. Something in that circuit has failed: The IC chip, one of the electrolytic capacitors (actually those do dry out over time and may well be your problem) or the power source from the flyback transformer may be out. Some or all of these may be involved. The good news is that all these parts are cheap and this repair is always worth doing.
Hope that ya fix it!
I would have the TV repaired, sounds like it has some good years left in it. I draw the line at 10 years old. My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Rating Locked! (?) snoopdog970 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on tv problem:
I don't want to Accept this solution
Solution #2
posted on Apr 20, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I NEED A SERVICE MANUAL TO HELP ME FIND WHERE TO GO CAN SOMEBODY HELP AND I WILL BUY IT, THANKS
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Solution #3
Not Rated (0)
alxz
Rank:Guru Guru
Rating: 86%, 34 votes
If you have any experience in soldering components, you may be able to fix the TV by simply locating the loose connections, near the vertical defletion circuit.
Thank You!
Can you Help with these Standard Televisions problems?
Sansui DTV2760 27" TV
i left my tv on and when i came back from running errands...
RCA F32648 32" TV
My sister has this 2001 TV and she says it has a mind of...
Sanyo DS31520 31" TV
i need the code number to program it in
Prima C1310B 13" TV
Do these tv's have digital tuners? Or, will they require...
Loading problems.
Repair Service
Find Standard TV Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
