Question about Nintendo Wii Console
Gah! Too many problems!
I got a new Wii for christmas, but there were no controllers and no ac/dc adapterin the newly-opened box. We sent it back and got controllers and an adapter but now there are more problems with it. For example NOTHING absolutely NOTHING happens when I put a disc in the slot. I may as well be putting the disc into a shoebox, because that is the amount of response I get. It still says "insert disc" even though I have. Also, if I go onto the Mii making thing, the screen goes blank and completely unresponsive after a few seconds, even if I don't touch a thing, and even if I do. What do I do? I don't want to have to send it back and buy a new one.Help please!
You wont have to buy a new one but since you got it for christmas you should be able to return it for an equal exchange at the store it was purchased from, from the sound of it, it is just a poorly made Wii.
Posted on Jan 03, 2008
Guitar syncing on softmod wii
Hello. you must first check that the batteries are good. then, check if your wii is working properly. if both don't help then you must get a wii or guitar!
Jul 29, 2012 | Nintendo Rock Band for Wii
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
What's your problem? the wii wont turn on
    • 1 Disconnect any accessories, such as GameCube controllers or SD cards.
    • 2 Unplug your Nintendo Wii AC adapter from the wall outlet and from the back of your Nintendo Wii. Leave the adapter disconnected for two minutes. Reconnect the adapter to the console and plug the outlet end straight into a wall outlet, not a surge protector.
    • 3 Remove the AC adapter from the wall outlet again. If the Wii has yet to turn on, the problem may lie within your electrical outlet. Plug a lamp, nightlight or something electrical into the outlet the AC adapter was connected to. If the outlet appears to work, then you'll have to test the AC adapter itself.
    • 4 Run your fingers along the AC adapter cable and visually look for any damage, such as frayed wires or a cracked piece of cable. Also look for the model number "RVL-002" and "Wii" on the adapter. If you don't see the "RVL-002" model number and "Wii" on the adapter, then you are using an unlicensed adapter, which can cause instability and power failure. If the adapter has incurred any damage, you will likely have to buy a new adapter.
    • 5 Spray air to clean out the vents on the back of the Nintendo Wii. If your Wii has been sitting for a long time, then dust and dirt may have built up around the vents, preventing the console from cooling itself. If the console cannot cool itself, it overheats and shuts down.
    • 6 Click "Start," "Internet Explorer" and visit the Nintendo repair page (see Resources) to open a repair claim. If you tried the above steps and your Wii has yet to power on, your system probably needs professional repair.
Oct 05, 2011 | Nintendo Wii Console
My wii will not turn on
Hi,Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
First:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
Second:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
Third:
- it might be cheaper to replace the AC adapter with another one
Fourth:
- get the unit repaired
Thanks and good luck
Jun 03, 2010 | Nintendo Wii Console
Wii won't turn on
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
While you're waiting, check the AC Adapter for the following:
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power
good luck .
rate please !
Mar 23, 2010 | Nintendo Wii Console
Adding new controllers when original is lost
hello,
i have looked around for you and i beleive all you need to do is press the Sync button on the Wii (not the Wii Remote) for 15 seconds to reset it.
and it should work like a charm to get you back to throwin some curve's in wii sports!!!!!
i hope i have helped and i hope it works!! let me know how it works
Jan 03, 2010 | Nintendo Wii Remote Controller
AC & Heater Fan on fast spped only
Most of the time this is a bad "blower motor resistor". It is easy to replace. You will find your behind the glove box in the ac/heater (evaporator) housing. Below is a pic of the resistor as it is seen from behind the glove box. 1. resistor assembly. 2. harness 3. fasteners (2). 4. lower edge of glove box. (open).
Jun 11, 2009 | 2002 Chrysler Town & Country
No sound on animal crossing
lol just calm down put the wii speak in the wii as simple as that eh?
Jan 11, 2009 | Nintendo Animal Crossing: Let's Go To The...
Need pin connections to lg vx-4500 for DC charger
The phone side connection should look like this image
Nov 18, 2008 | Cell Phones
Nintendo wii wont turn on
do you know any one else with one try using there powere pack ?
other wise it's defective.
Dec 28, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
