Hi, The problem is in video board which is A board, It needs replacement, your cost of repair can be reduce if the repair in your region available on component level, and if not available on component level then you have to replace the complete video board. Thanks for using fixya.
Was this helpful?
Yes
No
Popular Solutions for Westinghouse LTV-32w1 32 in.
Sometimes the colors get all distorted (could be described as a negative reverse color). Typcally...
(More)
Sometimes the colors get all distorted (could be described as a negative reverse color). Typcally the darker colors. The best way to describe is like watching a bad 60's psydellic light show. Over the last few months the problem is becoming more frequent. It comes and goes, on its own. Any ideas on what is wrong? Thanks Charles
after 30 min of use the tv goes black and there is no sound? is there a simple solution or is it...
(More)
after 30 min of use the tv goes black and there is no sound? is there a simple solution or is it time to replace?
Hooked up DVD player to 32" Westinghouse HDTV and now all dvd's are in black/white and fuzzy,...
(More)
Hooked up DVD player to 32" Westinghouse HDTV and now all dvd's are in black/white and fuzzy, along with only having 3 total channels! Help!
on a ww refrig control panel, inside refrig, i removed two screws but control panel will not move...
(More)
on a ww refrig control panel, inside refrig, i removed two screws but control panel will not move down to replace defrost board. frez is like a refrig. runs a lot. MODEL# ED5SHAXMT
