Televison & Video Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There was a bang inside the television and the power cut out also unable to recieve the sky via the sat but we are able to recieve sky via the tv analog
AMJAD HUSSAIN
Level 3:
  • Axsion Master 586 Answers
  • Posted on Nov 01, 2009
AMJAD HUSSAIN
Axsion Master
Level 3:
Answers
586
Questions
Helped
206017
Points
1533
The bang you are talking about is of capacitor popped in power supply. Replace the popped capacitor with new one and it will work fine again.
Thanks for using fixya.
(U.K. Question) How do I manually tune my new Smart tv to find Sky via the Red Eye?
Question edited for clarity.
Although I had Sky in the UK before I moved to Canada, I am not conversant with this infra-red device. Scanning on a television is normally reserved for over-air signals via an aerial. Picking up specific device is via HDMI inputs, via Bluetooth or via other devices that are connected to your home WiFi network that the Smart Television can see.
I found this
and this
Your new and improved Sky+
Sky https://www.sky.com > help > articles > your-new-and...
We're updating all compatible Sky+HD boxes with the latest software (R023.091.33.00P) to improve the reliability of your Sky+HD box.
Rdr dc90
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Hope this helps..........
We bought a hitachi 50hxt 16u tv and are unable
tried to replace the HDMI cable then set the right source.check also your box which not working.
1helpful
2answers
No signal being recieved
Sure the sat is getting power?
Lg 42 plasma - loud bang/spark smelly smoke and small flame inside.
It is a short circuit caused by some components and/or power capacitors. This may need assessment by a qualified service technician.
Can't record from tv to dvd
I think you would have to run your sat line through the DVR-1600 first (Line In) then connect directly from the DVR to one of your TV Line-Ins (Audio R, Audio-L, S-Cable Video).
And then use the Cyberhome TV Tuner to record off your sat.
3helpful
2answers
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
4helpful
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
2answers
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Top Axsion Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Axsion Televison and Video Expert? Answer questions, earn points and help others
