Question about Remote Controls
Roctec contol hello, i have a roctec p.i.p. with out a remote controler. i can't find the right code for universal c. . what can i do? sorry for bad english. thank's ,   lue
  • 3 Answers
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
Posted on Jan 30, 2008
SOURCE: codes for philips remote contol pm 625s
He is right
pm625s & pm725 codes are same
Posted on Feb 24, 2008
  • 217 Answers
SOURCE: program contol RMT-U220
Posted on Jun 27, 2008
  • 26 Answers
SOURCE: RCA Universal Remote Code
Here are the codes for Philips. If these do not work you have to use the code search feature.
Philips........002,006,007,010,011,013,016, 033,035,037,038,043,066,073
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD,
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button,
for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-7.
Posted on Nov 17, 2008
  • 7 Answers
SOURCE: Remote control OR Remote control code. This link will take you to the Philips Support site where you can download manuals and code sheets for your remote. You may have to do a manual search for you code. The manual has instructions to do this. Good Luck!!
Posted on Mar 29, 2009
  • 66413 Answers
SOURCE: hello i have a philips universal remote control
Get into this site. You can download the user manual for your SRP2003/27 from here. It is in PDF format. OK.
Posted on Sep 03, 2011
0 characters
1 Points
Hello, I need a remote code for my Citizen DVCD668 to work with my RCA RCU404R universal remote contol. Thanks in advance!
Use code search on your RCA remote to find something that works. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Aug 07, 2016 | RCA Remote Controls
How to get code for remote contol
To which device do you want setup codes? Waht is the brand name of the Remote control you have?
May 12, 2012 | Universal Remote Control GAMER Remote...
I can't find a code for a Systemlink3 universal remote for a Durabrand TV.
RCA systemlink-3 universal remote control has no setup codes with Duraband TV. Sorry.
Oct 13, 2011 | RCA Remote Controls
Do you have a code for tivax converter box
No, sorry I don't think so. Universal remotes only have codes for TVs. A Tivax Converter Box is kind of like a CD-DVD player right. If so, sorry I don't think it does have a code.
Jun 06, 2009 | RCA 3-Device Universal Remote
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Mar 29, 2009 | Universal Remote Control 6-Device...
Codes for philips remote contol pm 625s
here are the codes, it's a pm 725,but the codes for phillips are standard for their brand and they should work.
Feb 24, 2008 | Philips PM625 Remote Control
Universal remote code
Hi Joni,
Im not certain of the model of your remote contol but I think this web sight might help your problem to locate the proper codes. I hope this helps.
Universal Remote Control Codes
NC Electronic
Mills, Wyoming
Jan 25, 2008 | Remote Controls
Need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Jan 12, 2008 | Jensen JER-422 Universal Remote Control
Remote Controls Logo
Top Remote Controls Experts
Are you a Remote Control Expert? Answer questions, earn points and help others
