Question about Sanyo ECD-T1550 CD Player
Sub I see that there is a little red light on the face titled SW it is to right next of the LOUD led can someone tell me what this is for im hopeing it for sub hookup but i could be wrong
  • wweave12 Nov 16, 2008
    yes i have that same problem i dont know how to turn on my sub
  • 132 Answers
There is a sub preout on that deck, the light i belive if for when sub mute is on
Posted on Jan 03, 2008
6ya staff
SOURCE:
Cadence 400 watt active sub green light on, no sound from the sub. whats wrong?
proceed according and fix it. However yi\ou must read the diode LED for diagnose. God bless you
Mar 26, 2013 | Exercise & Fitness
Im having trouble hooking up the power switches and reset sw and hdd for msi km4m-v
Ok what you want to do is go over to the JFP1 Switch connection on the motherboard. It will be labeled and it has multi colors and 5 pins on one side ad 4 on the other. Starting with the 5 pin side the pin that does nat have a partner on the otherside where the 4 pins are stays empty. Immediately next to that are the two pins for the reset sw...notice the + and - symbols on them. On the wires that you have colored or striped is positive and white or nonstriped is negative (this may also be labeled on the little colored wires)...plug in the reset sw wires into those two pins. don't worry you won't damage the board by doing this wrong..you just won't get lights (at which poing you'd just redo it etc)...the next two pins over are for the HDD LED...plug those two in,...now the 4 pin side...there's the empty slot...then next to that is the power sw. Plug those two in there...next to that is the Power LED...plug those in there...note that the colors do not necessarily match up to their respective pin/wire colors so just read the labels and you'll be good to go...that's it...test by turning on and seeing the colos light up on your PC...if you notice the Hard drive indicater light blinking every time the Hard drive is in use then you're in good shape...takes practice but it's not too bad once you get the hang of it...Good luck!
ASpecialty4You.com
Dec 21, 2009 | MSI KM4M-V Motherboard
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Mar 05, 2009 | E-Machines eMachines T3830 PC Desktop
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Nov 30, 2008 | PC Chips M848ALU Motherboard
P4VMM2 motherboard
You can download the manual from here (Europe) or here (US).
Sep 17, 2008 | EliteGroup P4VMM2 Motherboard
EMachines T3256 Desktop
Generaly, the little connectors on the printed side will face the bottom of the case. Also, typically, Black is negative, and white/colour is positive (except on the power sw, it doesn't matter). On the motherboard, where the connectors go, there should be some kind of print saying where to plug them in. (IE, POWER SW, would go into PWR, and HDD LED would go into HDLED and POWER LED would go into PWRLED).
It may look different than this, but generally the same kind of layout, as you can see, it shows the positions, as well as positive and negative.
The fact that the fans are running indicates that your power Sw is connected properly.. Make sure that you didn't accidently pull out/loosen anothe connection to the motherboard/harddrive.
Sep 05, 2008 | E-Machines Athlon XP 2200+ (rb-t2200-c67)
Emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
Jul 28, 2008 | E-Machines eMachines Desktop PC
42PF7321D/37 LED Light Blinking RED
my dad had this happen too. after some research, we found out that there are two capacitors on the power supply board right next to the connector for the main logic board that went bad. you can just pull those out and solder in new ones, and it works like new again! i found a repair kit on ebay for $35 including shipping, and that's all it took!
Jul 17, 2008 | Televison & Video
Motherboard
I have one sitting in front of me , unfortunately I cannot get it to you but will be happy to tell you the positions. It's not very difficult to fix and I will stick by until you get it correct. I hope I don't complicate this in an attempt to keep it clear and don't be insulted by my answer. I am guessing you don't have a great deal of experience working inside the box and it can become confusing. This is much easier than the length of this answer suggest. You will do this in about 30 seconds, move anything that is in you way and make a note of where it came from. If your hand is small you are lucky but don't force anything and if you are pushing on anything trying to get down there see what it is before pushing more. Better to move it.
There is a front panel connector that is on the bottom right of the board if you orientate the board by placing the computer access panel in front of you with the front of the computer facing to your right. Then right below the floppy disk controlled socket (the smallest flat cable in the box) if no floppy the empty socket below the battery.
There is a double row of pins, looks like 2 rows of 10 pins each. Mine are multicolored, pink and green etc. and the should be marked + and minus, at least plus. The number 1 pin is on the left. The 1 pin is actually the bottom left and the 2 pin is above it. Back down to the bottom row and pin 3 is right next to 1 and the 4 pin right above it. Pin 3 is the second pin on bottom left. Follow the way it goes? The bottom is 1, 3, 5, 7, 9, 11, 13, 15, 17, 19 and right above 2, 4, 6, 8, 10, 12, 14, 16, 18, 20.
Pin 2 is + so put your Power SW on pin 2 and 4 with the colored wire on pin 2. Colored wire in the pair should be positive, and it can be blue, red, green, mine is red and white.
The Power LED goes right next to the Power SW on pins 6 and 8, the colored wire on pin 6, mine is blue and white. And finally the HDD LED goes on pin 7 and 9. All counting from the left to right. My pins are not marked as I think its not critical how the LED is connected and if it does not light then reverse those 2 pins. My colored wire is on pin 7 and its blue. May as well finish, the Reset button is wired to pins 17 and 19 with 17 being positive and the speaker if you have one hooked up (your tiny internal speaker not for listening to music) is a 4 pin connector with the middle 2 sockets empty and fits over the last 4 pin s on the bottom right. 13, 15, 17, and 19. Pin 13 is +. There may be other wires but I don't know where they go depends on what they are but this is what you need. Good luck. And make sure all is unplugged and touch the box to ground yourself or wear a strap. Look but don't touch is a good rule for now.
Feb 22, 2008 | Computers & Internet
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Mar 11, 2007 | Pioneer GM-232 Car Audio Amplifier
Sanyo ECD-T1550 CD Player Logo
107 people viewed this question
Top Sanyo Car Audio & Video Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Larry Tezekjian
Larry Tezekjian
Are you a Sanyo Car Audio and Video Expert? Answer questions, earn points and help others
