Question about HP Pavilion a305w (DM181AR) PC Desktop
Computer has power but won't start up
When i turn the power on the computer begins to start up and then it freezes with HP INVENT LOGO ON SCREEN. any suggestions?
  • Sammot Nov 23, 2008
    I have exactly the same problem. Nothing happens when I try to press F8 or any other key for that matter.
    I have a brand new HP Pavilion a6655 Desktop
    I tried removing the battery on the motherboard for a few minutes (this helped someone with a similar problem) but it didn't help.
    Problem Solver:
  • 4 Answers
Sounds like your PC hang during POST, which mean some hardware is not behaving right. The first thing you could try is to reseat the memory (RAM). If you have two or more piece of RAM, remove all except one, then try each one to see if it will boot. Then the second thing you could try is unplug the hard-drive. Sometime a faulty harddrive will prevent PC from detecting it and cause POST stuck problem.
Good Luck!
Tony
Posted on Jan 09, 2008
    Sergeant:
  • 263 Answers
At the start up press F8 within 5 seconds and then select las t good know and then restart the computer if this does not help you may have to repair windows or change hard drive
Posted on Jan 03, 2008
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
I downloaded the upgraded ROM on my IPAQ 910 (P/N FB050AA#ABA) and experienced problems. Now the unit cannot even load. When turned on, it shows a page with HP logo with these information: RUU..., HP...
why not ask < HP>>>>???
its old, almost nobody uses these now....
are you going to spend money on this thing?
why change the BIOS? ROM best is not to unless you know
the BIOS update fixes a known issue you have, no issues stated.
https://h30434.www3.hp.com/
Jul 17, 2017 | HP iPAQ 910 Pocket PC
Computer will not start screen comes on HP invent
Hi.
This is a problem with HP/Compaq wherew the motherboard "freezes".
Here's a way that might just "thaw" it out.
First, disconnect EVERYTHING from the computer EXCEPT for the keyboard and mouse and screen.
Unplug the computer.
Next, while unplugged, press and hold the power button for at LEAST 45 seconds.
This allows the bios to reset to an available state.
Then release the power button and then plug the computer in.
Boot up.
The computer should now boot normally.
This is known as a "soft reset".
Hopefully this works for you, as it has worked well for many others.
I hope I helped you out, and good luck !
Mar 13, 2011 | HP Pavilion a450n PC Desktop
WHEN I POWER ON MY DESKTOP COMPUTER,BLUE SCREEN APPEARS TOGETHER WITH THEY HP INVENT LOGO.IT DOES'NT BOOT.
Hi.that may mean your pc has crashed.what kind of operating system where you using?dont know much about xp but windows 7 automatically recovers from that.try using the recovery disc for that operating system
Jan 25, 2011 | HP Computers & Internet
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
Hp compaq will not boot, sticks at hp invent screen with F10
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. See if the described symptoms also happen on your laptop. If you did experience random freezeups or slow DVD you're dealing with the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Oct 26, 2010 | HP Compaq nx6110 Notebook
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
Turn om computer.hp/invent page
sorry i don,t get it. please more details what hapen
Dec 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Stuck at hp invent starting screen on a a310n
Bios Chip HP is bad replace Invent screen is the bios screen telling the pc what to do. I replace mine at less than $6.00 170343718185_11.jpg Seller: *bios*depot2010 good luck Plus
remember get a back up and install program on other hdd. not (c)
Aug 17, 2009 | HP Pavilion a310n PC Desktop
HP Pavilion a305w (DM181AR) PC Desktop Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
