Question about Uniden Cordless Phone
My uniden DECT 6.0 phone is picking up interference
I have this interference which goes away when I disconnect my wireless router.
  • Phoneless Jan 03, 2008
    How can I make this work?
    Scholar:
  • 56 Answers
Hi Phoneless,
Normally TWO NOISE FILTERS comes with net packs (modems and netlines instalations from the companies by default). One of them, we swich to the phone line, separating Data and Audio tranfers. [the outside cable goes directly to the router and the filter is connected between the box in the wall and the phone cable(preferred one), or between the cable and the phone].
If you don't have it, ask to a Phone Company, that's is real chip and helps a lot to whom shares phone and internet in one line [ ...as me too...beside...as almost everybody :-) ]
Posted on Jan 19, 2008
6ya staff
SOURCE:
How can i bost the signel on a linlsys E1000
Make sure the latestwireless card driver is installed in the computer.Locate the wireless routerhigher and away from concrete and brick walls, foil-insulated walls. Locate the wireless routeraway from cordless phones and microwave ovens these can cause interference.You could be gettinginterference from other wireless access points or wireless routers in yourarea. Check the wireless broadcast channels in your area, and select one thatis unused or one that has the weakest signal strength.
Feb 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
When on a cordless phone connection to internet is lost with wireless internet
Most wireless routers transmit over the 2.4GHz frequency, which is the same as many cordless phones. If you can, move the router or the phone so that they are far away from each other. Otherwise, the easiest thing to do is buy a cordless phone that operates on another frequency. (Most phones display their frequency on their packaging.)
Feb 18, 2011 | Linksys Wireless-N WRT150N Router
Answering machine picks up after 3 rings .
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jun 20, 2010 | Uniden DECT 6.0 Cordless Phone ID
Can the d-link dir-615 interfere with the telephone?
It can interfere with cordless phones. It won't with a wired phone.
The cordless phones operate in the same frequency band so sometimes they wil interfer a bit. What will hapeen is the voice or sound quality won;t be as clear or if real bad it will drop calls. The 2.4 and 5.8 ghz phones can have problems with the wifi and the microwave.
The newest Dect 6.0 style phones are designed to be immune from both microwave and wifi interferance. We went through a series of phones at home before we found out about the DECT 6.0 types and all of our problems went away.
Jun 02, 2010 | D-Link DIR-615 Wireless Router
My phone cuts off laptop wireless
Wifi typically operates in the 2.412Ghz - 2.472 Ghz depending on the channel selected. ideally the Wifi modem/router and the DECT phone should be operating in completely different bandwidths.
If your DECT phone is cutting off your Wifi wireless connection, then they must me operating in similar/same range: you need to change either your Wifi or DECT frequency 'channel' to minimize this interference.
Also make sure that there is a least 3 meters between the DECT base station and your Wifi modem/router to eliminate Transceivers static RF/EMF interference.
Hope it helps: let me know how you go.
Jan 12, 2010 | Uniden Cordless Phone
Wifi interference??
The short answer is that it could interfere with the wi-fi, but your wi-fi should not interfere with your phone because it uses WDECT, "wide-band digitally enhanced cordless telecommunications" engineering. No matter how tight the bandwidth is on any RF transmission, power, proximity, and harmonics all play a roll. Ideally we want the power from our transmission to occupy the target frequency but the reality in RF is that this is nearly impossible without DSP filters. I have pasted some extra info below to help answer this question.
Digital Enhanced Cordless Telecommunications
(DECT), known as Digital European Cordless Telephone[1] until 1995, is an ETSI standard for digital portable phones (cordless home telephones), commonly used for domestic or corporate purposes. It is recognised by the ITU as fulfilling the IMT-2000 requirements and thus qualifies as a 3G system.
The four most common frequencies today are 900MHz, 2.4GHz, 5.8GHz and DECT 6.0:
900 MHz Currentlythe most common frequency for cordless phones, 900MHz phones may offera greater range than other frequencies. However, the 900MHz spectrum iscluttered and may result in interference with baby monitors and other900MHz cordless phones. Radio scanners can also easily pick up thisband. 2.4 GHz 2.4GHzphones offer better clarity and security than 900MHz, but mayexperience some interference with microwave ovens and wirelessnetworking (wi-fi) products. 5.8 GHz Themost advanced cordless phones available, 5.8GHz phones transmit on anew, open frequency and have the least chance for interference. Theywill not interfere with wireless networking (wi-fi) products. DECT 6.0 DECT6.0 operates on the 1.9GHz frequency. Though newly approved in the US,this frequency has been used for many years in Europe and can increasecall clarity and security. The wi-fi friendly DECT technology easilyintegrates into homes with wi-fi and internet services because the1.9GHz frequency is exclusive to DECT, making it interference free forcordless communications.
Jul 19, 2009 | Uniden Lands Phones
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
2 Wire DSL Wireless modem range expander
you might want to try to change the wireless channel 1. open your internet browser 2. type on the address bar 192.168.1.254/management or 172.168.0.1/management and press Enter 3. type your system password (modem password) 4. go to home network -> wireless 5. change your wireless channel to 9 - 10 if after changing the channel it still wont work please check for EMI (Electro Magnetic Interference) such as electric appliances, hallucinogen lamps, WIRELESS PHONES, satellite dish and or alarm systems. also make sure that you dont put your router on a carpet. usually a good distance between your router and the computer is around 5 - 20 feet with no walls between them since walls also contribute on the interference. one last note, keep your router away from water i.e. aquariums, water dispenser and the like since water contributes to the interference of the wireless signal
Feb 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Uniden Cordless Phone Logo
175 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
