Question about Canon PowerShot S230 / IXUS 179 Digital Camera
Canon s230 My camera is not recognizing any CF cards that I am trying to use. Any solutions?
  • Canon Master
  • 4,738 Answers
You might have a bent pin in the CF slot. Take a look inside this slot to verify. If so, remove the battery and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Posted on May 14, 2008
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
My Canon EOS Rebel XT doesn't recognize the CF card. It recognized it earlier, but I removed it and now it won't see it. I also tried a different CF card and it didn't work.
LOOK INSIDE THE CAMERA Card SLOT AND SEE IF ALL THE PINS ARE STRAIGHT You may have bent the pins which is easy to do. If they are bent it will be a serviceman job to replace the module
Please rate my help++++Thanks for using FIXYA
Nov 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Horizontal lines taking photos
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jul 14, 2009 | Canon PowerShot A95 Digital Camera
Canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
May 29, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Canon 5d cannot format cf care
Hi there, did you check the card itself? SD cards have a locking switch on the side. Move the switch from locked to unlocked. Put it back in the camera and see if that helps.
Rob
Mar 02, 2009 | Canon EOS-5D Digital Camera
PowerShot G1 + cf card
The Canon G1 was my first digital camera, years ago. When this camera was sold it came with a 16 Mb CF card. The manual refers to CF card sizes from 8 Mb up to 128 Mb and the number of photos you can take with each size card. However, I bought my camera together with a 1GB "micro drive" (tiny hard drive in a CF card format) and although it wasn't "supported" by Canon, it worked fine. I also used a regular 1GB CF card in it (after I lost the microdrive card). If you want to use a card larger than 1GB with this camera, test/borrow a card to make sure it works before you buy one. Camera stores always have a variety of cards (used to demonstrate the cameras they are selling) that you can put in your camera and test before you decide which card to buy.
Dec 15, 2008 | Canon PowerShot G1 Digital Camera
Dead LCD - is there a fix?
Understand how you feel, I love my A75 too. But forgive me if this seems obvious, but did you try pressing the DISP button on the back of the camera with the camera turned on? If so, next have you tried downloading your pictures to view them on your computer? Are they also black like your screen? If so, the problem may be a defective CCD imager. Canon should then fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Sep 17, 2008 | Canon PowerShot A75 Digital Camera
I have a Power Shot S230 but my new system (Vista) does not recognize the driver for the above camera. I do a lot of pic work and need desperately Bill O'Brien bobrien@onecom.com
In order for Windows XP or Windows Vista to communicate directly with a digital camera, the camera must be PTP (picture transfer protocol) capable. This protocol was developed after the PowerShot S230 came out six years ago. Your best bet would be to get a CF card reader (only about $15 - $20) with a USB connector and use it to read the photos from the CF card.
Sep 02, 2008 | Canon Cameras
Canon powershot S230 Camera will not take picture now
Oct 28, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
My CompactFlash card is no longer recognized by my computer (Sony Vaio notebook w/Windows XP home edition)
It isn't clear from your description, but are you inserting the reader into your USB port, and *then* inserting the CF into the reader? If so, try reversing this -- insert the CF into the reader, then insert the reader (with the CF) into a USB port. It is possible that your PC is only looking at the reader once (when it is inserted) and not finding a CF, then ignoring the CF once you insert it. If your camera can read and write to the CF, then it is unlikely that the CF is damaged. Since you have determined that the reader is ok, and since your PC recognises the reader, it is unlikely that it is a USB driver problem. Similarly, it is unlikely that it is a physical problem with the USB port, or the pins in the reader or the CF card.
Mar 03, 2007 | Canon PowerShot A50 Digital Camera
Canon PowerShot S230 / IXUS 179 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
