Kenmore 23822 Top Load Washer
Problem for Kenmore 23822 Top Load Washer
The little oval hole where the washer lid with a
By obers4 on Nov 01, 2009
The little oval hole where the washer lid with a pin sticks into to make the machine run is not functioning. We can bang the lid or put a screwdriver down in the oval hole to maintain contact, but it's getting more and more difficult to find the spot and maintain it to get the cylcle to finish. Is is worth fixing???
Solution #1
posted on Nov 01, 2009
Not Rated)
salde386
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 94%, 65 votes
yes, it's worth fixing,take out the two screws holding the top control panel,i think on your washer they are in the back of each side of panel,if not pop off the corner covers on the left and right side of panel and remove screws,top panel is on hindges,lift it up and there will be two metal clips,use a straight blade screw driver and stick it in the part of metal clip that's cliped into the top of washer and push back on screw driver and that will release the clip,put them down on a table the same way you took them out so you'll remember how to put them back in.unclip the lid switch wires,they are plugged in to the top of washer,now tilt the frame up and pull to you and you now can get at the lid switch.put it back together and you should be all set
Was this helpful?
Yes
No
Popular Solutions for Kenmore 23822 Top Load Washer
Questions and Unsolved Problems for Kenmore 23822 Top Load Washer
Do you recommend Kenmore 23822 Top Load Washer?
Answer
Answer
washer does not start. filled up with water but then stopped. Attempted to unplug and plug. still... (More)
Answer
What is the capacity of the Kenmore model 110.82370820 washing machine?
Answer
kenmore 00622991 in the spin cycle the tub rachets and makes loud noise, the tube is turning every... (More)
Answer
could you please advise about water level of kenmmore water level?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
