i guess ur using a licensed and updated antivirus (i prefer avg/kaspersky)..!! this is a common problem now days, probably itz caused by a virus/trojan..
try using only -- http://login.facebook.com/login.php
download microsoft KB890830, install n run
also possibilies of: u may not hv java runtime/adobe flash player/shockwave player installed.. the windows firewall is limiting the site.. may b ur antivirus is doing so.. some spyware/trojan horse also may play foul.. sometime it also depends upon the browser u r using.. may b it is black-listed or restricted by using 'content advisor' (in case of ie) in ur computer by some user or the above.. may b it is being filtered by the 'phishing filter'.. there may b possibilities that the site may contain 'active content'..
howevr i/we'll try n make u know.. but b sure u pass positive with all the above criteria....
Nancy,
The following could go wrong while logging into FaceBook:
a) There being no internet connection.
Ensure that the internet connection is working.
b) The Login IS and password could be wrong.
Ensure that both these are correct. Sometimes we press the numlock inadvertently and then there are problems if you are on a laptop. Please ensure that all the little green LEDs are off.
If you have ensured all these, there is no reason why you should not be able to log into FaceBook.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 3100 PC Desktop
Hi, I have installed Realtek ALC888S driver on an Acer lowcost PC but the device 'HD AUDIO' shows up...
(More)
Hi, I have installed Realtek ALC888S driver on an Acer lowcost PC but the device 'HD AUDIO' shows up twice - once with the working driver and secondly without driver installed. So I remain with one device that has no good driver installed. The effect occurs both in Windows XP and in Windows 2003. Anyone any ideas? Tks Ronald
Network assistant(DELL) programme apparently expired, this was followed by variouse functions not...
(More)
Network assistant(DELL) programme apparently expired, this was followed by variouse functions not enabling I.e SYSTEM RESTORE page contained no text just a blank page, also SEARCH&HELP FACILITY would not work. I have spoken to DELL, their advice to me was to delete DELL NETWORK ASSISTANT from my pc,as after the expiry date it would no longer apply. This i did do, allas things got worse, JAVA problems, internet problems(would connect to welcome page but could not progress any further, seems to be a progressive malfuntion, the more i tried to overcome the sittuation, the worse it was getting. GET ME OUT OF HERE, SPACER
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and...
(More)
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and boost the battery but it went into hiberate and wont restart or work. Is there a switch that I have turned off by accident under the laptop?
how do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is...
(More)
how do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is mentioned in the manual but other 3 mention was fc pga thanks for any help
