Question about Ovens
GE XL44 Gas Range, Gas Smell Inside Oven
We have a GEXL44 gas range, older model, JGBS15GER2, and find a slight gas smell inside the oven noticeable when opening the oven door (we have shut the gas off for now). Warm soapy water did not reveal any leaks to the flexible hose/line connections in the back of the unit. What to test next and how? The oven control valve? If it is this valve, is this a complicated replacement endeavor?
  • Anonymous Mar 31, 2008
    I have Chef Chateau deluxe Automatic Infra ray gas oven. When I try to shut it down there is always small flame coming out at the bottom.Flame is not fully going. I dont know what is the problem.Can you please help me out.
SFroese
  • 141 Answers
SOURCE: Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Posted on Sep 06, 2008
  • 306 Answers
SOURCE: XL44 Gas Range will not light
Kinda sounds like the hot surface igniter is out. It is located under the oven section under the bottom panel. They are relatively easy to replace except you need that oven today I'm sure. Let me know how it turned out.
To replace the hot surface you need to take the bottom panel off and access the assy you need a 1/4 nut runner and remove couple small screws unplug the igniter take it to a parts house and 12 to 20 dollars later you're good as gold. When I say parts house appliance parts.
Posted on Nov 27, 2008
SOURCE: Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Posted on Feb 02, 2009
mgprice
  • 744 Answers
SOURCE: oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Posted on Aug 17, 2009
TheMobilian
  • 8220 Answers
SOURCE: kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 14, 2010
I have a GE Profile Gas Range model 317B6034. The top / range works fine, but the actual oven will not turn on at all. I don't smell gas nor is there any sound when I turn the oven on. Basically,...
It sounds like you have a bad ignitor in the oven. Hope this helps get you going in the right direction.When you turn on the oven the ignitor should glo.
May 16, 2011 | Ovens
My ge profile gas oven is brand new, when we turnit on it smells and gets soot on the inside ?
My GE oven smell like gas when I turn it on. Oven haven't been used in a while.
Sep 18, 2010 | GE Ovens
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Feb 02, 2009 | GE Ovens
Sep 06, 2008 | Ovens
Oven gas
For safety purposes call gas technician to check your gas pipe. If stove turn off supposed not to smell gas.
Jul 23, 2008 | Frigidaire FGB24S5A Gas Single Oven
Tappan gas stove,oven not lighting
yes replace the lower oven ig nighter you can do this from inside the oven pull the racks out then locate two screws in the bottom oven pan take the out pull the bottom plate then pull the flame spredder pan and you will see the glow bar replace that most common for you compliant
Jun 03, 2008 | Ovens
Ovens Logo
299 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
