Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Bad color The test prints show no yellow and limited red so I assume I have a print head or two clogged.  The color prints really badly.  How do I manually access the print heads to clear them?
  • 1 more comment
  • zoems Jan 03, 2008
    I know how to do this and it isn't working. I wondered how to actually get inside the machine and clear the heads.
    Thanks,
    Janet
  • Anonymous Jul 19, 2008
    Won't let me clean print heads. Tells me to put in new cartridge. Changed cartridge and did a "clean heads twice and tried the third time and was told to change cartridge again.
  • lhousel Aug 31, 2008
    I went through two cartridges and never got the number of prints expected.
    Now it says the ink saturation pad is full and will not clean again.
    Any way to clean the ink jets? Lighter fluid ? compressed air? alcohol?
  • Epson Master
  • 1,879 Answers
Follow these steps to clean the print head using the control panel on the printer:
1. On the Main Menu, press UP or DOWN arrow to highlight More Options, then press OK.
2. Press UP or DOWN arrow to highlight Maintenance, then press OK.
3. Press UP or DOWN arrow to highlight Clean Print Head, then press OK.
4. Press OK to begin cleaning the print head.
*NOTE: The cleaning takes several seconds, during which the message 'Cleaning print head. Please wait.' appears on the screen.
5. When cleaning is complete, you see a message asking if you want to print a nozzle check pattern. To see if the nozzles are clean, load a sheet of photo paper, then press OK to print the nozzle check.
6. Check the pattern to see if there are any gaps in the lines. If there are gaps, press OK to clean the print head again. If there are no gaps, press Cancel to go back to the PictureMate Main Menu.
Posted on Jan 03, 2008
2 Suggested Answers
ohms
  • 1879 Answers
SOURCE: color bad
The printed copy shows the red color as pinkish or magenta.
Assuming that you have the printer set up correctly and are using the latest drivers for the printer and the printer software, this is probably caused by clogged ink nozzles in the black, yellow and cyan inks. It may also be down to compatible rather then geinuine inks being used. Try the print head clean function and see if that helps
Apr 01, 2011 | Computers & Internet
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Oct 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The cartridsge printe red and blue fine. No yellow
The print head for the yellow color may be clogged. Check the manual to see how to turn on your print head's cleaning system. Run it until the yellow starts to print properly. If after running the cycle 4 or 5 times you still can't get any yellow to print you will probably have to take the printer to your local repair depot to have them diagnose the problem.
Jul 11, 2009 | Office Equipment & Supplies
My Canon Pixma i90v has been working great for a year and now all of a sudden the color cartridge isn't working. I've done a print head cleaning and a deep clean. The test print shows that the black works...
If the printer is not worn out, one of the first things to try is to remove the printer in the computer settings. Reboot the computer and reinstall the printer software. This ensures that you have not gotten bad or corrupted drivers.
Apr 28, 2017 | Canon Office Equipment & Supplies
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Xerox Phaser 8500 color issue
In all honesty, I suspect the print head has some bad jets on it.
Xerox will not warrany it since there is the presence of non xerox ink in the print head.
When you have tried as much as you have with the maintenance cycles. I would suspect a bad printhead.
When the jets become blocked to the point where you cant get all the colors sprayed onto the drum, you get mismatched colors.
Apr 07, 2008 | Xerox Phaser 8500/DN Printer
No yellow ink
It sounds like you have a clogged nozzle. First I must assume you are using refilled compatible cartridges. You should change the cartridges for genuine Epson ones before proceeding.
Run 4 or 5 head cleaning procedures through the printer driver. DO NOT DO THIS WITH COMPATIBLE INK IN as this can make the problem worse.
If the clog does not clear or show significant improvement after 3 or 4 cleans, contact this person for information on intensive head cleaning for your machine.
Mar 27, 2008 | Epson Stylus C43SX InkJet Printer
Color bad
Jan 03, 2008 | Epson PictureMate (C11C556001) InkJet...
All colors print blue
You did the right thing. Sometimes a bad printhead or a bad cartridge will cause a leak and will damage both. Good job!
Jun 05, 2007 | Canon i850 InkJet Photo Printer
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
333 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
