Home | Creative Labs | ZEN V Plus MP3 Player | How do I change bat...
Creative Labs ZEN V Plus MP3 Player
Problem for Creative Labs ZEN V Plus MP3 Player
How do I change battery on my mp3 player
By desertjeep4x on Nov 01, 2009
how do I change battery on my mp3 player
Solution #1
posted on Nov 01, 2009
Not Rated)
diaphanous
Rank: Apprentice
Rating: 100%, 1 votes
with a creative zen v plus, it's gonna take a little time and some prying, but it's fairly easy. First, snap off the bottom piece where the play and return buttons are. underneath should be the contrast color piece. then, take a small screwdriver and carefully remove that contrast piece. it should snap off. when that's off, the top will look the same but you should be able to see the motherboard. In the right corner there's one screw you'll have to take out to get to the battery. but first, the screen. this is where the prying starts. you need to get underneath a little all the way around, and pry it off bit by bit. it took me about ten-fifteen minutes to get the screen loose without damaging it. it's still attached, but when you lift it you'll be able to get at the second screw. once both screws are loosened you'll be able to lift up the motherboard and screen to get at the battery. the volume control cover piece just falls out but just replace it before you put the screen down again. the battery is stuck down, but just disconnect it from the motherboard (there's a little white plug ) and pull it off. replace the battery, and when you put the motherboard back in, lift the screen a little so the usb port, line-in, and headphone jack can slide into the holes. replace the screws, press down the screen, and snap the contrast and cover pieces back in. you're done.
i don't recommend doing this too often, as the screen will become really loose. be really careful, and make sure not to hit anything with the screwdriver. good luck!
Was this helpful?
Yes
No
Popular Solutions for Creative Labs ZEN V Plus MP3
Questions and Unsolved Problems for Creative Labs ZEN V Plus MP3
Do you recommend Creative Labs ZEN V Plus MP3 Player?
Answer
Answer
my creative zen was working perfectly, then the screen was white an it wouldnt show anything but i... (More)
Answer
My mp3 player comes up with only a white screen. It does not come up with any displays or anything.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Creative Labs ZEN V Plus MP3...:
Top MP3 and Digital Med... Experts
Rank: Guru Guru
Solutions: 450
Experience: By using this stuff I know what I know when I know, but sometimes don't know how I know you know??
Ask Me
Find more MP3 and Digital Med... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
