Question about Epson PictureMate (C11C556001) InkJet Photo Printer
Color bad When I print a test there is no yellow ink at all and somewhat limited red.  So I assume I have a print head or two clogged.  How do I manually clear those?
  • 4 more comments
  • vroadrunner Feb 14, 2008
    I have same problem, no yellow showing at all. I started with new ink and did recommended cleaning several times, still no yellow, all other colors working and my ink showing only 1/2 cartridge. any idea how to fix only yellow? i tried to print something only yellow hoping it will get the ink going but nothing. Any idea how to fix it without taking it to repairs?
    thanx
  • Freddy35 May 14, 2008
    I have the same problem but a different color is missing.. I've gone throught the cleaning process many times and it doesn't change.. I just keep going through new cartridges.... Can this be done manually????
  • nycusa May 25, 2008
    Also have limited yellow coming through making all photos appear quite blue-toned. Have tried the clean print head action many times with no difference.
  • Cairse Nov 22, 2008
    My pictures come out red. I have performed the nozzle check, replaced the ink cartridge and done a head cleaing several times each but no luck. Thanks for any help.
  • Anonymous Apr 21, 2009
    prints only mgenta, this is the second new cartridge, tried cleaning a ton of times.
  • Anonymous May 14, 2009
    i tried the solution above and now the printer says i need to replace the brand new cartridge. thanks alot!
  • Epson Master
  • 1,879 Answers
Follow these steps to clean the print head using the control panel on the printer:
1. On the Main Menu, press UP or DOWN arrow to highlight More Options, then press OK.
2. Press UP or DOWN arrow to highlight Maintenance, then press OK.
3. Press UP or DOWN arrow to highlight Clean Print Head, then press OK.
4. Press OK to begin cleaning the print head.
*NOTE: The cleaning takes several seconds, during which the message 'Cleaning print head. Please wait.' appears on the screen.
5. When cleaning is complete, you see a message asking if you want to print a nozzle check pattern. To see if the nozzles are clean, load a sheet of photo paper, then press OK to print the nozzle check.
6. Check the pattern to see if there are any gaps in the lines. If there are gaps, press OK to clean the print head again. If there are no gaps, press Cancel to go back to the PictureMate Main Menu.
Posted on Jan 03, 2008
I have done that a few ink cartridges ago. It does not fix the problem. How do I really clean the heads?
Posted on Jul 10, 2008
2 Suggested Answers
ohms
  • 1879 Answers
SOURCE: bad color
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
The printed copy shows the red color as pinkish or magenta.
Assuming that you have the printer set up correctly and are using the latest drivers for the printer and the printer software, this is probably caused by clogged ink nozzles in the black, yellow and cyan inks. It may also be down to compatible rather then geinuine inks being used. Try the print head clean function and see if that helps
Apr 01, 2011 | Computers & Internet
Not printing all colours, heads clogged? Printing red and blue but not yellow.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. Make sure that the yellow ink is not empty. If it's not empty, head may be clogged.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
If that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 11, 2010 | HP Photosmart D5160 InkJet Printer
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Oct 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
INK JET PRINTER NOT PRINTING RED - GREEN HUE ALL OVER
the mixture of red is a combination of magenta and yellow ink or toner, if either one of these color is out of quantity or not working, chances are you will not get the right color. hope this helps.
Nov 19, 2009 | Epson Stylus C88 InkJet Photo Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
No yellow ink
It sounds like you have a clogged nozzle. First I must assume you are using refilled compatible cartridges. You should change the cartridges for genuine Epson ones before proceeding.
Run 4 or 5 head cleaning procedures through the printer driver. DO NOT DO THIS WITH COMPATIBLE INK IN as this can make the problem worse.
If the clog does not clear or show significant improvement after 3 or 4 cleans, contact this person for information on intensive head cleaning for your machine.
Mar 27, 2008 | Epson Stylus C43SX InkJet Printer
Bad color
Jan 03, 2008 | Epson PictureMate (C11C556001) InkJet...
Red and Yellow not Printing at all.
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry!  A replacement might costs more than a new mfc 440cn!
Oct 16, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson PictureMate (C11C556001) InkJet Photo Printer Logo
434 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
