Question about HP Designjet 110plus nr InkJet Printer
Error code 42:10
Can anyone tell me what part and how to replace it for this error code? I get this code 3 times a year. this cant be right.
    Problem Solver:
  • 16 Answers
Carriage Motor failure; Replace the Carriage Motor Assembly.
Posted on Jul 30, 2009
I have model # MDE6700AYW (Maytag Neptune electric dryer) Error code T5, service codes 0, 19 and 76. Can anyone tell me what part needs to be replaced?
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Here is a link to the part in case you need it.
Aug 23, 2011 | Maytag Neptune MDE6700A Electric Dryer
Error code 80023121 how do i fix it
You get this error code when you try to log in in psn right now.. dont worry because your ps3 is perfectly fine you get this error code because you cant sign in to psn right now because psn is under maintenance and there is no definite time of when will it get back.. so just relax... you wont get the error code by the time the psn is working again..
akuma_ryu21 i hope this helps..
dont forget to rate.
Apr 27, 2011 | Sony Playstation 3 (PS3) Console
Hi..I did like you said and it worked for two minuets and now the yellow led flashes 4 times on my Pronto 91. could you tell me what that error code means.
This is a common problem with the M91 when the motors are more than several years old.
An error code of 4 flashes indicates a right motor fault. The right motor could have a short or open circuit, or a bad connection.
Check the right motor, connections and motor cable visually and with a voltmeter at the connector. Look for cuts, nicks and breaks in the wiring and for grease oozing out of the gearbox. Flip the seat back and remove the top cover. Disconnect the black square right motor plug and check the resistance across the red and black motor wires using a digital volt meter. 0 to 1.6 ohms is OK, anything out of this range is suspect.
If the motors are more than 3 years old, you should consider replacing the motor/brake/gearboxes as a pair, left and right. The motor/brake is about $650 with the motor/ brake/ gearbox assembly about $1,000 per side. Labor is 2 to 3 hours total. I usually replace the brake/motor/gearbox as a complete assembly to avoid future problems. Hope this helps.
Jan 11, 2011 | Invacare Pronto M51 Power Wheelchair
Kidde nighthawk model KN-COPP-3 has error code 09, can anyone tell me what that code means?
Congratulations, error code "E09" is the grossly under-documented "planned obsolescence feature" called, rather matter-of-factly, "End of Life". This means that ~7 years after first being powered up, the unit will, BY DESIGN, cease to function, forcing you to buy a replacement. Would have been nice of Kidde to include THAT warning on the OUTSIDE of the package. Call their "Hotline" at 1-800-880-6788 and tell them what you think of that policy. If it is still under warranty (5 or 7 years depending on date of manufacture) they should replace it. In any event, buy another one; if they replace your first one you will have twice the protection. Not a bad thing. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab Instructor
Oct 17, 2010 | Kidde Nighthawk Combo Gas/co Detector
I have a Mitsubishi WD-57732. The problem started
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp)
(Lamp-Enable goes to DM but not to Ballast) It's related to the lamp.
Mar 26, 2010 | Mitsubishi WD-57732 Projection Television
Model#asu9cq error code
need model and make, and serial if you have it, its an error code, but without make, cant tell u!
Aug 05, 2009 | Fujitsu 18C1 Air Conditioner
GE FTP18
I have the same problem, although my oven is 3 years old. I am having the door latch replaced today. cost $240. The repair company that I contacted sid that these ovens are their bread & butter!!! If I could afford it I would ship all of my GE appliances(which are only 3 years old mind you) to them and tell them to shove them!! I alreadt spent over $200 on my GE dishwasher which at the time was only 1 1/2 yearsd old.Did you clean the oven before the error code started flashing?laurieslovett@yahoo.com
Jun 25, 2008 | GE Profile JTP18 Electric Single Oven
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
Error code 0020
a solution?!ok my suggest is throw away the fuckin' 360 'n buy a PS3.every time i fix that ***** another fuckin code appears.i've had 0102,0001,0020.0133!so the solution is fuckin' the fuckin' Bill Gates 'n all the microsoft./
Jan 05, 2008 | Microsoft Xbox 360 Console
ROL??
if you have 4 flashing red segments, then it's a graphic VGA lead problem, 3 flashing segments means a hardware failure.
If you are continually getting problems, return it to your retailer for an exchange as Microsoft guarantee the 360 for 12 months on hardware failure.
Oct 15, 2007 | Microsoft Xbox 360 Console
HP Designjet 110plus nr InkJet Printer Logo
219 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
