Question about Holmes Products (048894556579) 4 Gallon Humidifier
Will not reset
I have a Holmes HM8405. I am trying to get it running this year. Replaced the filter. Reset light will not go off for anything. Any ideas?
  • lne216 Mar 18, 2009
    I already did this several times!
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
Posted on Dec 27, 2008
Holmes 2060w runs but no water is evaporating
change the filter and check for fan moving to circulate the air in the unit
Nov 24, 2013 | Holmes Products Humidifiers
My lennox furnace works just fine except that 25% of the time the fan keeps running when it shouldn't and blows cold air
You are using too restrictive of an air filter. If the codes you are getting off the lights says anything about a high limit this is the cause of your blower running all the time. Use a less restrictive filter or have your contractor install a media filter in the system. if you reset the furnace and it does not stop running the blower you have a stuck limit switch and may have to get another or call a service tech to reset it or replace.
Oct 27, 2013 | Honeywell Power Humidifier: Furnace...
Holmes HM5700 Won't reset. Screen comes up with reset and starts counting down form 450
Mine did this also so I unplugged it and took it apart and cleaned it. I used a sponge to clean all around the heating element with a mixture of white vinegar and water and also put some in the water resevoir and shook it for a few minutes and rinsed it out. It ran perfectly after I did this. It gets mineral deposit build up after a while so you might need to do this every week. There are directions on the back of the humidifer that explain this and what you should do. I hope this helped
Oct 30, 2010 | Holmes Products Warm Mist HM5700...
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried...
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Post comments  for more help or information .........
Good Luck!!
Dec 22, 2009 | Holmes Products Cool Mist HM3500...
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
possibly calcium or other deposits from the type of water you are using in the unit..........
Feb 03, 2008 | Holmes Products Holmes 3 Gallon Cool Mist...
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Holmes Products (048894556579) 4 Gallon Humidifier Logo
680 people viewed this question
Top Holmes Products Humidifiers Experts
ray gallant
Ben Eng
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
