Question about Philips 42PF7320 42 in. EDTV-Ready Plasma Television
TV shutsoff after 20 min
The issue is that after approximately 20 minutes, the TV shuts off and needs to be unplugged for a period of time before it will start up again.
  • 2 more comments
  • Anonymous Jan 03, 2008
    The issue is that after approximately 20 minutes, the TV shuts off and needs to be unplugged for a period of time before it will start up again, but the issue is current again and again
  • MDCND Jan 03, 2008
    Yes, my issue is similar it happens continuously.
  • PhillipSucks Aug 10, 2008
    Surprise! Surprise! I've had my set for about 2 years and it's doing the same thing. I'm furious to know that it's $500+ to fix. And I WILL NOT ever buy another Phillips product, no matter what it is.
  • Anonymous Nov 30, 2008
    Dear fellas. The same problem happened to me, but didn´t enjoy my tv for as long as the 2 year guy, it was just 6 months that I used my tv and started to happen.
    Any recomendation to an unsatisfied Phillips buyer?
    Sergeant:
  • 395 Answers
Replace the SSB modual
Posted on Jan 03, 2008
REPLACE POWER SUPPLY BOARD
Posted on Feb 24, 2009
6ya staff
SOURCE:
Have a Remington space heater, runs for approx. 10 min. then shuts off, then if unplugged or switch turned off, then it will start again for short period of time
There may be an overheating sensor that is causing shutdown after 10 minutes. After a cooling off period, it is ready to heat for another 10 minutes.
Dec 04, 2016 | Heating & Cooling
Panasonic pt52lcx15 TV. Recently, after approximately 5 min. The TV turns off. Is this some sort of power supply issue? Or, something else?
Try this.
Unplug the tv. take off the back panel. vacuum or blow out the dust with a can of compressed air (@ $3 at Staples). A lot of the projection tvs had a thermal sensor which would turn the tv off if it got to hot.
That is also a good time to clean the lenses. Be careful not to move them out of alignment. My tv worked like new after I did those things.
Jun 10, 2015 | Panasonic Televison & Video
Tv shuts down after 20 mins or so need to unplug for a time to re start then will run again for a short time
projector tv works like a projector.
the superhot bulb needs cooling, and if the cooling fails, it shuts down.
so what you have is either the fan is not working, or the cooling system is not working.
have to fix it professionally.
Jul 01, 2011 | Hitachi Televison & Video
There are pinholes developing in my screen. Can you tell me why and how to repair it?
Try connecting any other device to the TV to confirm that the issue is with the TV. Then, you can try resetting the TV to the factory settings. If the issue persists, you may try power resetting.
To reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
If the issue persists, you can get it serviced from the nearest authorized service center.
Jul 12, 2010 | Televison & Video
I have a KDL46VL150 that has started cutting off after viewing for a while. The standby lights blink a sequence of 6 times. Usually if i unplug or cycle power to off and wait a bit it will return to normal...
It indicates that there is an internal malfunction within the TV. You can try Power reset.
To Reset the TV, please disconnect the power cord for a short period of time (approximately 1 minute). Then, reconnect the power cord and power on the TV.
You can also try connecting the TV directly to the wall outlet.
If the issue persists, I suggest that you get the TV serviced to fix the issue.
Jul 12, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Red power lights blinks and tv will cut off. sometimes after you unplug it it will come on after about 10 min. now it will not come on unless you unplug it and then it will work about 5 min and cut off...
depending on the age of your tv, this appears to be a common issue. Blame it on the ballast board. your ballast might not be able to provide the lamp w/ enough voltage to keep the image on for longer period of times. or it could simply be that you need a new tv lamp.
Apr 13, 2010 | Toshiba 55HX70 55" Rear Projection...
Pioneer plasma pdp4214hd shuts off after being on for about 20 min.
Are you able to turn the TV back on immediately or do you have to wait? If the TV is consistently shutting off around 20 minutes, this may indicate an overheating issue. It is possible that you need to clean the TV out of dust or it may mean your cooling fan is dead or not revving up when the temperature rises. If you are not able to turn the TV back on right after it shuts off, overheating is likely the issue, as you would be forced to wait until it cools down. If you are able to turn it back on, for how long? Does it continue to shut off after another 20 minutes? It is possible that the thermal sensor on the mainboard is defective, or that the software that controls the sensor maybe corrupt. Service or a firmware update may resolve this. You would have to contact the manufacturer.
Oct 17, 2008 | Pioneer Televison & Video
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Wii / No Power
or you can remove all of the plugs from the console: AC, remote sensor, AV. This is important: You must also unplug the AC from the electrical outlet. Then wait 45 seconds, then plug the AC adapter back into the wall and your console. Power On.
Dec 25, 2007 | Nintendo Wii Console
Philips 42PF7320 42 in. EDTV-Ready Plasma Television Logo
218 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
