i've sony vaio vgn-fz430e.sometimes i cant switch on my laptop.after some hours or after a couple of day i can switch it on. when i press power button the first two lights power and battery will be on. also after that power button doesn't work i've to remove the battery only. is thos the problem with ram..? i've 3gb ram but still it's slow. help me out.
it could either be your motherboard or the power button connection with ur motherboard, still u can once take the ram('s) out and attach them back, make sure u do this while your computer is off.
also do it only if u know how to do it...else u can take assistance, cause sumtimes this can void the warranty if ther is ne....
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested. never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up. Soft surfaces also block the vents causing fans to run more and burn out sooner.
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if...
(More)
i have a sony vaio laptop and i dont know how to set up the security motion eye and im not sure if its software i have to download or its internel and i cant find it in my control panel
i have changed computers and am unable to access jigsaw puzzles purchased in the name of...
(More)
i have changed computers and am unable to access jigsaw puzzles purchased in the name of morag.milne@dsl.pipex.com when i type in reg key it is refused and i am unsure whether i should type the number"0" or the letter"O"
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system...
(More)
tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system menu but then image error pops up with a black screen. cannot use laptop i think i may have lost data. pleeeeaaaaase can somebody help.
