Question about NetGear Wireless-G USB Adapter (WG111NAWG111US)
NetGear Wireless G USB 2.0 Issues
Hello...I bought the Net Gear wirless G USB 2.0 adapter for my sons laptop and after we installed showed there was a connection beween it and our router....problem is I can not get on the net. Any suggestion or answers would be Great!
  • 556 Answers
Jane -- several things are required for internet access.
Lets go through step by step and assure the pieces are in place.
I will assume you have a second machine working with the router (wired or wireless does not matter). I would like you to try the following on both machines at let me know what happens.
First you can connect to the router and not have access to the internet. This first to determine the IP configuration values are correct for your network. (assumes Windows XP and probably Vista) - using the working machine
Click Start then All Programs the Accessories then Command Prompt a new window will open -- in that window type the following (one space only before the /)
ipconfig /all
and press enter -- record the following in the responses
IP Address --------------- probably 192.168.0.?
Subnet Mask ------------ probably
Default Gateway -------- probably
DNS Address(es) ------ may be more than 1
on your son's laptop do the same -- you should see the following if the configuration is right.
IIP Address --------------- probably 192.168.0.?
Subnet Mask ------------ same as working machine
Default Gateway -------- same as working machine
DNS Address(es) ------ same as working machine
Now test the connection to the router
in the same window as before enter the following command (replace the with the default gateway from the working machine if different)
The working machine should display 4 messages with elapsed times indicating the ping works.
Your son's machine may display 4 timeout messages indicating it does not work. If the ipconfig above is wrong especially in matching areas to the working machine that could explain the problem. It could also be that the adapter requires additional wireless configuration such as a WEP or WPA password or passphrase, or connection to your network name (SSID) if it is hidden.
Please respond to this issue with a comment telling me what matched in the two ipconfigs and whether or not the ping works hopefully yes at least on the working machine and I will probably be able to provide a solution to the problem.
Posted on Jan 03, 2008
Netgear wirless - installed on toshiba satellite a45 - S151 will not connect to internet router = comcast - linksys also causes conflict with connection of other wireless computer
Presumably, you have configured your wireless router:
* SSID (your "network name")
* encryption-level ('WPA' or higher security)
* password for your network
With that information, any wireless device (iPod Touch, iPhone, NetGear wireless adapter) should be able to connect to your wireless router.
Exactly what error-message are you getting?
Feb 21, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
My laptop computer says the adpter is not detected we have ran th
You can connect the Cat 5 cable from your laptop to one of the ethernet ports from router to download. Or download from any computer to a  Jump drive then install to your lap top.
Sep 08, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG111 doesn't see D-Link DIR-655 wireless network
Hi Joe,
I would suggest you to change the wireless channel on the Dlink and use the channel on which WG111 will scan and connect to your network. Also, plese make sure to use the security encryption on the DLINK to WEP or WPA only. Using higher security like WPA2 will cause issues with this adapter.
Jun 21, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Cannot connect to wirless with adapter on new computer
Although this model appears to support Windows Vista according to the manual for it ( the 64 bit version is not mentioned and, therefore, probably not supported. I'd take the wireless adapter back and find one that supports Vista 64 for certain. Some do.
Mar 27, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Can not install my router
First of all power off the net gear wireless adapter and than try to install the rangemax. if it dosen't work than please check the dhcp range in both the wireless router are the of the same range. than kindly the change the range of dhcp of this new rangemax wireless adapter. you can change this dhcp range my connecting the router to your computer and login by default ip . e.g and login with userid "admin" and password "admin" than go to lan management option and try the same.
Dec 03, 2008 | NetGear RANGEMAX WNR834M Router...
I have a netgear wg111v3 adaptor and a netgear wireless router. both setup fine and get on net ok. but when i turn my computer off then on again i have to re install my wireless adaptor. can u help?
-- try to install the adapter to a diff slot/ port
-- try to uninstall the driver and use updated driver downloaded from the netgear website to reinstall the driver
-- unistall old driver or other adapter on the computer to avoid driver conflict
May 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Usb 2.0 wlan
I had exactly the same problem and had to go to the PC card Netgear WG511
for some reason the USB one conflicts with some things on certain laptops
I now am able to get the internet wirless on my laptop
good luck it nearly drove my crazy trying to get it to work!
Apr 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Connecting my mobile
I an assuming that you are trying to access the phone through the sony software, which, i think asks how you intend to connect to your pc, if so try using a different usb port. if you are using Vista then there are compatability issues that ave not been resolved yet.
Feb 13, 2007 | NetGear (WG511U) 802.11a, 802.11g/b...
Computers & Internet Logo
214 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
