A E00061-0001 deals with the drum charge is missing. I would look to see if the primary charge unit is installed correctly, if so I would pull the unit out and make sure none of the corona wires are broken.. could be one of the post wires or the grid is broken. You may also, have a end block that is arching out. If you are not a service tech, you will need to call one to repair the code. It can't be cleared till it is fixed... Good Luck
The following message is on the display as well: "Turn the main power switch (on the main units...
(More)
The following message is on the display as well: "Turn the main power switch (on the main units right side) on & off again" I am unable to activate any of the buttons on the panel, not even the "on/off" button. The switch will turn if off though, but the message keeps repeating itself after the machine warms up.
i need frrimware fore canon ir 5020 i(frimware =boot ,language(france),systeme .....all frimware...
(More)
i need frrimware fore canon ir 5020 i(frimware =boot ,language(france),systeme .....all frimware fore ir 5020i) may e mail is fahimriad@yahoo.fr
