Question about Brother MFC-7220 All-In-One Laser Printer
Mfc-7220 Back Cover Open
I fixed a paper jam. Now the Back Cover Open error message will not go away and the printer is offline. Checked, rechecked. Interlock on back cover?? This is quickly becoming an oversize fax. Or paperweight. Thanks for your help!
  • 3 more comments
  • Anonymous Apr 08, 2008
    I too have an error message that says back cover open even though it is closed and there are no paper jams. please help, roxanne
  • Anonymous May 07, 2008
    Same here! Twice! I don't think that Business Depot will give me ANOTHER replacement unit! Anyone???
  • sjd5 Jul 25, 2008
    Yes, same problem. I've unplugged power, removed and reinstalled drum, opened back cover slowly and quickly, even tried shutting it hard. Still get the error message. Please help.
  • Anonymous Apr 15, 2009
    Joe
    Thanks, it worked like a charm. It was so simple once I knew what to look for.
    Mark
  • Anonymous Mar 22, 2014
    paper jam error on MFC-7220
This one made me crazy, but I finally figured it out. Turn the machine around so that you are facing the back. Open the back cover. Pull down the second smaller roller cover inside the machine. If you look closely at the second smaller cover, on the right hand side (closer the the inside of the machine), is a very thin round piece of plastic that is only half the length of the smaller cover. There are 2 thin plastic tabs attached to either end of this round piece of plastic. Gently shift this over so that the 2 plastic tabs can now go into the space provided for them. I had to move mine over only 1/4 inch.
Posted on Nov 13, 2008
I removed (carefully) and reinstalled the back cover. That solved the problem.
Posted on Jul 27, 2008
I have to print out a paper right away, could you help me?
If it still prints ignore it.
if you rather call the vendor. Ifyou're under warranty. They may replace or repair it.
Apr 18, 2015 | Brother MFC-7220 All-In-One Laser Printer
How to fix -saying ,close back cover ,and there is no open cover it does not work at all
If you turn the Brother printer off and then back on with a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Feb 06, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother all-in-one printer not working; error 'back door open'
Open the front cover and remove the drum and toner.
There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Jun 02, 2010 | Brother MFC-7220 All-In-One Laser Printer
MFC-7220 All-In-One Laser Printer: the back cover open message will not go away...
There is a paper jam in the machine which is blocking the sensor for the back cover.
Remoev the drum and toner (cartridge) from printer and look inside, there should be a piece of paper there, you need to remove it slowly
May 16, 2010 | Brother MFC-7220 All-In-One Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
I cannot get the BACK COVER OPEN message to GO AWAY. I tried to open the back black cover and check to see if there were any paper jam and i also opened the front cover and ejcted the ink toner and no...
There is a little cover there that has a sensor flag on it. It is most likely in a jammed position. If you are able to carefully take the cover out, you can bend it slightly, readjust the sensor flag, and reinstall it.
Thanks
Mar 12, 2010 | Brother MFC-7820N Laser Printer
Hi I had a paper jam in my MFC 8820d - I removed the cover and removed the paper but I still get a Paper Jam error msg. I powered down the machine and turned back on - still same error msg. I have removed...
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Sep 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
Back cover open error message MFC 7820N
Reseat inner rear paper guide to allow sensor to home correctly
Mar 09, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper jam in brother MFC 240C
Usually small pieces of paper are jammed at the print head area. Lift up the scanner and see if you can find the paper at the print head parking area, clear the paper . If you can't find the paper, remove the scanner cables, then the scanner. You will see 2 screws at the rear and one near the USB connection. Another 3 screws towards the front will remove the front panel. Under the panel remove 4 screws and the two panel harnesses. The is a speaker harness which you must remember to attach back later (most people don't remember to put back). Lift up the top cover and you can see the whole engine. Clear any pieces of paper that might be there.
Apr 20, 2008 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC-7220 All-In-One Laser Printer Logo
1,021 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
