XM tuning for Onkyo TX-SR575
I bought an XM-ready receiver. I even got the XM packaging open (both th mini-tuner and the home dock/antenna). It's plugged in to the XM input on the back of the receiver, and the antenna is plugged in.
According to the XM instructions, I simply tune to channel 1, then activate.
I've already activated, but how the *&@# do I "tune" ??? The mini-tuner itself doesn't have any dials or buttons, the antenna doesn't either. And the Onkyo instruction manual does not address XM, simply touts that it's XM ready.
I'm assuming the input selector should be CBL/SAT? But the tuning selector I use for FM has no effect.
Any ideas?
3 Suggested Answers
SOURCE: Audiovox Xpress XM Radio Home Dock Problems
home dock does not allow the fm frequency generator. it only works in the car dock
Posted on Jan 31, 2009
SOURCE: sirius/xm activation
Typical, they wont recognize sirius and xm on the same account. tyou need to close the old account and open a new account on the new brand head and start from square one. Also - they wont give multi head discounts if you have a mix of siruis branded heads and xm branded heads - each brand needs its own account and own e-mail address. They **** in this regard. Good luck, ive decided between this backwards book keeping and aneed to keep resetting my Sirius head periodicaly that neither is worth the aggrivation so I cancelled all of them.
Posted on Nov 09, 2011
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
Tx-sr575 7.1 - is there any use in connecting and old power amp and equalizer to this receiver? If so, how?
Ya mean like to hook up Bose 901's? Nevermind.
Utility is in the imagination of the dreamer.
Any analog processor can occupy the Tape Out/In loop. However, it will only affect stereo analog sources and, once engaged to monitor, it will disable any digital audio source.
An external amp COULD be slaved off the tape Out (or the anticipated EQ Out, but it won't be volume-controlled by the Onkyo. You would need an AVR with at least Front L/R pre-outs.
Aug 12, 2011 | Onkyo TX-SR575 Receiver
I have just tried to plug in a microphone on my TX-SR575 and now we can't get any sounds whatsoever.. PLEASE HELP!!!
Please tell us WHERE you attempted to get a mic to work on this unit. It might shed some light on what got blown up.
Mar 05, 2011 | Onkyo TX-SR575 Receiver
When I connect the sirius radio to the docking station (sirius connect home kit) I can hear the sound for a few seconds then the docking process engages and I loose the sound. I have the tuner set to...
Hello, I am sorry about your issue. I suggest that you contact Onkyo at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Jul 03, 2017 | Onkyo TX-DS575 Receiver
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
I have a Siriusconnect Home Tuner and an XM Ready Receiver. Will they work together? What do I need to make the connection from the 8-pin mini DIN on the Tuner to the XM connector on my Denon AVR-587?
Not gonna work, sorry to say. You need the little two-piece "XM Ready" tuner unit (with antenna) to plug into your XM Ready receiver. Sell the Sirius Connect Home Tuner and buy the XM unit. XM unit still available at some Best Buy stores.
Sep 19, 2009 | Sirius Satellite Radio Receiver
I don'tknow how to use the satellite radio...
Got this off the crutchfiel web site.
Item #700XMSON1 $129.98 This XM Direct 2 package includes everything you need to add XM Satellite Radio to your compatible Sony receiver: an XM Mini-Tuner, a CNP2000UC universal adapter, and a Sony connector cable. The Mini-Tuner connects to the universal adapter, then you use the connector cable to hook up the adapter to your Sony receiver.
Use your home computer to program the universal adapter for your Sony receiver — you can reprogram this adapter to work with another brand in the future. Once connected, you'll be able to change channels and see programming information on your stereo's display. You can also use the included XM Mini-Tuner with your XM-ready home receiver or in another vehicle with a compatible dock.
A computer running Windows XP and Internet Explorer is required. The unit is not compatible with Windows Vista.
Note: A subscription to XM is also required — learn about XM's programming. Satellite radio service is available only within Canada and the lower 48 states — not available in Hawaii or U.S. territories. Portable reception may vary by location. If you have questions about the proposed XM/SIRIUS merger, read the XM Customer Promise. To view this file, you will need the Adobe Acrobat PDF reader.
Apr 16, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
SR573... Does it support NTSC/PAL?.
There's no mention of either NTSC or PAL in any spec sheet.
This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220-240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Some aliases for the SR575=
You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
Apr 07, 2009 | Onkyo TX-SR573 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
69 people viewed this question
