Manfrotto (701RC2055MFV) Tripod Logo
Posted on Nov 01, 2009
How do I install a replacement leg clamp on my manfrotto tripod?
5 Related Answers
Paul Jones
  • 215 Answers
  • Posted on May 11, 2010
SOURCE: Broken leg clip on Manfrotto Modo 785B
Yes you can. But I saw that your Manfrotto is possible to buy for 50 Euro.
Anyway the part you need is the full leg called CODE:
R785,203B
you can see the datasheet on the spare part site of Manfrotto:
http://www.manfrotto.com/webdav/site/manfrotto/shared/manfrotto_nord/pdf/7/785B_20070503.pdf
Regards
PDG
Anonymous
  • 63 Answers
  • Posted on May 26, 2010
SOURCE: i need a lower leg clamp for my 190xb manfrotto
You can order the lower leg clamp as a part from http://bogentripodparts.com/parts/190XDB.htm
Follow the link and check for your part number.
Hope this helps,
Andrew
MIke
  • 685 Answers
  • Posted on Jun 22, 2010
SOURCE: Broken leg clamp, Where can I buy a replacement part?
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part
MIke
  • 685 Answers
  • Posted on Sep 23, 2010
SOURCE: Lost quick release clamp on tripod (manfrotto)
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Anonymous
  • 175 Answers
  • Posted on Nov 05, 2010
You can oredeer parts from
www.bogentripodparts.com
Manfrotto #190 tripod leg swings open and closed on its own versus having to pull with some muscle. How do I correct this? Thanks
Just strip down each leg individually, remove, clean and lubricate sparingly the leg clamps (I use silicone bicycle chain lubricant), wipe the leg sections to remove any accumulated detritus, then re-assemble. Do NOT over tighten the leg clamps - even the aluminium ones can be brittle and snap if over tightened.
Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
bogen and manfrotto are the same company
Manfrotto 028 Tripod foot installation
If you're afraid to "damage", maybe consider buying complete 'pod next time?
Jul 11, 2012 • Photography
1helpful
The tripod legs on my manfrotto 3433 slip. the clamping apparatus doesn't have enough grip and just the weight of my video camera is enough to make the legs start sliding down. I see an allen socket...
Hi toolroom347,
There are different clips on the tripod which allow you to adjust the settings for a firmer grip, you also need to extent the gap between the legs of the tripod for a firmer grip, this will help you to set the optimal settings for your tripod which will be fair enough to carry the weight of your camera.
Also a simple solution to stop this slip problem is to carry a small piece of cloth which has guide good grip or a rubber material and then place your camera on it , this will work excellent for a firmer grip.
This has definitely worked for me.
Hope this helps you as well...:)
1helpful
2answers
Broken leg clip on Manfrotto Modo 785B tripod the head is non-removable on this model and I don't want to have to replace whole tripod so is there somewhere I can buy a new leg clip or get it...
R785,203B
Regards
PDG
May 09, 2010 • Photography
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
I need a lower leg clamp for my 190xb manfrotto tripod.
Hope this helps,
Andrew
2answers
ART055 manfrotto pro tripod
Hey there fotoflika, I have had a similiar problem in the past and found replacement parts unavailable. My solution was to drill a small hole through the leg section, and I used a similiar size allen key to stick in the hole, effectively locking the leg in place. You could drill several holes for different extension lengths. Crude I admit, but cheaper than buying a new tripod.
Top Manfrotto Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Manfrotto Photography Expert? Answer questions, earn points and help others
